Question for stinger or dan
Old Aug 18, 2010 | 12:49 PM
Praetorian730's Avatar
Hey guys what type of lugnuts did u guys put on your rtr wheels, the stock ones obviously dont fit, because of the wide lip on the nuts. And the set I put on fit, however I noticed I blew out the cap (err the end) of one of the lugnuts as if the studs are too long.
Can u guys give me any suggestions, on a brand, type or measurement of what your using?
Old Aug 18, 2010 | 02:16 PM
montreal ponies's Avatar
I have used the stock Ford lugnuts for my RTR wheels, didn't change a thing about them.
Old Aug 18, 2010 | 02:47 PM
Really? the stock lugnuts seemed way to tight, and i didnt wanna chance destroying the wheel putting them on
Old Aug 18, 2010 | 02:58 PM
I actually removed a wheel just the other day to relocate a spring. It is a bit tight but with a 1/2" deep socket i worked just fine. I obviously didn't use an impact gun.
Old Aug 18, 2010 | 03:07 PM
Ltngdrvr's Avatar
You could always go with someting like these.
http://www.summitracing.com/parts/GOR-21183HT/?rtype=10
I think they make them in black too.
Old Aug 18, 2010 | 03:58 PM
Hmmm ok thanks for the info guys, i might try to use the stock ones, i was just being my picky myself and didnt wanna risk damagaing anything.
Althought black ones would be cool too
Old Aug 20, 2010 | 08:13 PM
mystickeith50's Avatar
I got a set of flat black gorilla lock systems lug nuts. they fit perfect with the rtr's and look sweet.
Old Aug 21, 2010 | 08:14 AM
Update, I actually did end up getting a set of gorilla locks, they fit perfect and look good. As a side note to anyone who may get rtr's or even an aftermarket rims. There these washer like nuts on the rotors, one on each wheel. That almost has a star pattern on them, you wanna absolutlely make sure you take those off.
The stock wheels have a indentation for clearance, so if u dont take those off, the wheel wont be flat, and your gonna have a safety issue on your hands, and a ton of vibration in the wheel. Pat @ classic design concepts was able to help me out with this problem, hes the man.
Old Aug 21, 2010 | 12:23 PM
This is what I did.
I actually already had them on my black bullitts and then just transfered them over. I didn't want shiny lug nuts on these wheels.
I'm glad your wife let you keep the wheels Praetorian.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
