Pros and Cons doing 275/40/19 on brembo wheels
I'm thinking of upgrading my tires soon so I need some suggestions.
First, what are some pros and cons of doing 275/40/19 all around? I'm not sure if anyone is running this setup and if they have any rubbing up front. (or 275/35/19)
My second thing is to just leave the front 255/40/19 and do 275/40/19 in the rear. Would this change the cars setup at all?
Would I need to recalibrate the speedo? I don't think so, but I'm also not very educated when it comes to tires.
Third part is some tire suggestions. I think the P's are nice but they wear out pretty quick. I need a good tire that will handle very well both in rain and summer. What are some good options here?
I just don't want to pay 400+ a tire. That's an outrage, I know they are good but not for 400, I have a set of bfgoodrich mud t/a 35-12.5r15 and they were way cheaper, like 200 bucks each cheaper. And don't get me wrong I'm not a cheap skate and I like good rubber but there ha to be a more affordable tire that compares to the P's
The 275's will be a little bit taller, making your speedometer read a little slower than you are actually going. I would do the 275's on the rear only. I'll be replacing my Pirelli P-Zero's with a less expensive all season performance tire when they wear out - likely 255's and 275's front and rear.
From a strict pro/con it's pretty easy actually.
On the pro side, you get a bump in your section width and total contact patch. The way the front suspension is designed on mustangs, they really like as much grip as possible. This means going with as wide of a tire as possible at all 4 corners. I believe Sam Strano was running a 285 up front on an 8.5" wheel on his autocross S197.
From a handling perspective, you'll gain grip, but with the tire seated differently on the wheel, you're going to lose a little bit of initial turn in. Stretching the tire on to the wheel as Ford does with the S197 chassis cars helps turn in and creates a more aggressive steering wheel.
Going to a 275 you're no longer stretching the the tire on to the wheel. You're going to gain grip and road holding at the expense of a bit of turn in and steering feel.
Wide tires also tend to tram line on road surfaces worse. So you're probably going to run in to that as well.
The stock tires on the brembo package already provide quite a bit of grip. For every day driving in a non competitive setting my own opinion would be to stay with the stock sized tires.
If you need that extra grip, certainly go for it. Or heck even if you just like the look of a wider tire.
On doing a staggered set, you can really change the driving dynamics of the car when doing this. Theses cars are setup pretty neutral from the factory. Going with a wider tire in the rear is going to inhibit a bit more understeer as you've added grip in the rear vs the front. So you've gone from neutral to plowing in the corners. Again though, not something you're going to notice in day to day driving. For track purposes you're going to want to run a matched set of tires front and rear.
Run 255s on front to help with turn in, etc. and run the 275s in the back with a bigger rear sway bar to either make the car more neutral again, or if it is big enough take away even more understeer and add some oversteer.
I'm a big fan of running a non staggered set up. Makes the tire last longer due to rotation ability. Especially with how much i predict the rears will wear faster than the front ![Wink](https://themustangsource.com/forums/images/smilies/wink.gif)
I'll probably go with a 265/40/19 when i need to replace mine.
EDIT: Neverming on the 265. Hancook doesnt make a tire in that size. 275 it is!
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
What size of rear sway bar will you need to bring back the neutral feeling with the 245/275 stagered set up on 9 X 19 brembo wheels?
Which tire do you recommend for the rear'35s or'40s. And for a neutral handling with 275 staggered, Which size rear sway bar do you recommend?
I am running 275/40/R19 all around on my 2011 Brembo GT.
I have stock suspension, ZERO rubbing issues. Sure I paid a little more for my wider tires up front, but I can rotate them, and they last a hell of alot longer that way. Looks better too, but thats just my opinion.
I have Michelin Pilot Sport All Season tires, so far they have lasted 46,000 miles with half spirited, half conservative country and city driving. As of today they have maybe 15,000 miles left on them before considering new tires. I kept my Pirellis, but so far have not found a reason to use them for every day driving. My mustang is a daily driver, I've got the pirellis mounted on some black ford racing brembos for any random track days i care to join in.
As for the speedometer calibration, it was almost negligible on my car. maybe 1 or 2 mph off (faster) when the speedo reads 70
M3hunter
9/10/15 09:26 AM
