Problem filling tank
Old Mar 16, 2012 | 07:02 AM
JCStang's Avatar
Anyone have this issue, I went to fill up yesterday since I knew the weekly 10 cent jump would be coming soon, had a little below 3/4's of a tank...started filling and the pumped immediately clicked off and gas poured out the opening...tried taking nozzle out and reinserting but kept doing it..I gave up after getting a whole $1 in...well some of it made it in.
Old Mar 16, 2012 | 07:54 AM
LEwis26's Avatar
There's a TSB for this.
Bring it to your dealer.
Old Mar 16, 2012 | 08:14 AM
montreal ponies's Avatar
Have you tried some of the common fixes people have posted for this? Like twisting the gas pump nozzle 15-45 degrees left/right? It has worked for me multiple times and I only have to twist it like 10 degrees.
If that doesn't work, fill a gas can and transfer it into the tank until you get it to the shop to get fixed. That should work fine.
Old Mar 16, 2012 | 09:21 AM
cinque35's Avatar
holy crap, i thought they fixed that problem 5 years ago,
same thing used to happen on my '06, never happened with the '10
Old Mar 16, 2012 | 03:29 PM
MusicMan66's Avatar
It's not the car sometimes, it's the pump/nozzle. This has happened to me a couple of times, but only on certain pumps, even ones at the same gas station. Never had mine into the dealer for the issue -- I just know to twist the nozzle a bit if it clicks off mid-fill.
Old Mar 16, 2012 | 03:47 PM
JCStang's Avatar
When I went to a diofferent station today...no problem, was able to fill it...
Old Mar 16, 2012 | 04:21 PM
ShaneGT's Avatar
and now world hunger has been solved... there is gas in the tank...
hehe
Old Mar 16, 2012 | 05:24 PM
SD CALSPCL's Avatar
Used to happen on my 2007, had to do the 45 degree dance to make it fill, but not the 2011, as yet. However, my wife fills at the same station and her '09 Passat started doing it. I am wondering if this isn't a problem associated with the auto off systems in the pumps, since she moved to another pump and it worked fine.
Old Mar 16, 2012 | 05:45 PM
dogiebitt's Avatar
Happened on my 2007 Eclipse once. I told the gas station attendant and he didn't seem alarmed or anything, even tho there was like a puddle of gas under my car.
Old Mar 16, 2012 | 10:42 PM
stupidgenius36's Avatar
Just Plain Rude!
****, that's crazy that they still have that problem. I wouldn't have thought it'd be that hard to design a gas tank, but apparently I don't know ****. As mentioned try twisting the nozzle (although that's never worked for me). Also as mentioned, changing pumps (even at the same station) usually works for me.
Old Mar 17, 2012 | 01:07 AM
watchdevil's Avatar
I constantly had this problem with my 08... Sometimes I would have to do as others have and turn the nozzle 45* so I could fill it without clicking off.
I have not had this problem at all with my 2010.
watchdevil's Avatar
Oops... post duplicated.
Rando
Aug 25, 2021 11:12 AM
unnoticedtrails
Jul 17, 2017 11:10 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
GLOCKer
Sep 28, 2015 05:20 PM
