Paint peeling 2013 GT
It's worth a try at the dealer. I would however say that was done chemically via brake fluid. Has anyone filled the master cylinder reservoir recently like at a jiffy lube, etc. ? If so they dripped some and it attacked the paint. That's exactly what brake fluid will do to paint.
I haven't done any work there since I got the car March of 13. No one else has done any work on my car since then either, except one trip to the dealer for a front end noise and crappy sync update. I know that means I'm over due on a brake fluid change, but that hasn't been touched. I am however the second owner, but the car only had 7k miles on it when I got it.
I guess that could mean the brake fluid could have leaked out of the top and dripped.
This is very common when you use your brakes a lot and heat up the fluid. This will happen if you do a lot of canyon driving spirited driving or obviously if you track your car.
The clutch line is not braided SS.
Looking at the picture closer, O see it appear to be a Stock Factoy Clutch Line, like someone else said, it probably just over flowed enough to drip on the paint below and eat the paint!
If it were me. I would hit it with some 1000 grit sand paper. Spray some self etching primer on the spot. Then I would get myself some grabber blue touch up and spray it over.
It's a pretty difficult spot, but I do have some touch up paint from when someone ran into my bumper a little over a year ago. I may have to go ahead and do the repair myself.
