Paint peeling 2013 GT
Old Jan 17, 2016 | 04:33 PM
clucas's Avatar
Changing the oil today with my son, and I noticed some paint under the noise pipe going into the cabin was peeling up. The car just turned over 41k recently. I'm probably out of luck with warranty right?
Old Jan 17, 2016 | 04:38 PM
2014GHIGGT's Avatar
It's worth a try at the dealer. I would however say that was done chemically via brake fluid. Has anyone filled the master cylinder reservoir recently like at a jiffy lube, etc. ? If so they dripped some and it attacked the paint. That's exactly what brake fluid will do to paint.
Old Jan 17, 2016 | 04:42 PM
wvtrain's Avatar
Looks like Brake Fluid dripped on the paint below the Master Cylinder, was the Clutch Line Changed on the car?
Old Jan 17, 2016 | 04:47 PM
clucas's Avatar
I haven't done any work there since I got the car March of 13. No one else has done any work on my car since then either, except one trip to the dealer for a front end noise and crappy sync update. I know that means I'm over due on a brake fluid change, but that hasn't been touched. I am however the second owner, but the car only had 7k miles on it when I got it.
I guess that could mean the brake fluid could have leaked out of the top and dripped.
Old Jan 17, 2016 | 05:03 PM
wvtrain's Avatar
Is the car a 6 speed. Mamnual? Because it appears to be a SS Clutch Line!
Old Jan 17, 2016 | 05:16 PM
clucas's Avatar
It's manual, and the car was 100% stock when I got it. I haven't done a clutch line swap.
Old Jan 17, 2016 | 05:20 PM
wvtrain's Avatar
Is the Clutch Line Braided SS?
Old Jan 17, 2016 | 05:22 PM
redonblackpony's Avatar
This is very common when you use your brakes a lot and heat up the fluid. This will happen if you do a lot of canyon driving spirited driving or obviously if you track your car.
Old Jan 17, 2016 | 05:25 PM
2014GHIGGT's Avatar
I just think the line is covered in a black loom. That's how it looks to me.
Old Jan 17, 2016 | 05:27 PM
clucas's Avatar
That could be it, but instead of track or canyons its daiky traffic in Atlanta.
The clutch line is not braided SS.
Old Jan 17, 2016 | 05:28 PM
wvtrain's Avatar
Looking at the picture closer, O see it appear to be a Stock Factoy Clutch Line, like someone else said, it probably just over flowed enough to drip on the paint below and eat the paint!
Old Jan 17, 2016 | 05:31 PM
2014GHIGGT's Avatar
If it were me. I would hit it with some 1000 grit sand paper. Spray some self etching primer on the spot. Then I would get myself some grabber blue touch up and spray it over.
Old Jan 17, 2016 | 05:36 PM
clucas's Avatar
It's a pretty difficult spot, but I do have some touch up paint from when someone ran into my bumper a little over a year ago. I may have to go ahead and do the repair myself.
Turbov6
1994-2004 V-6
Jun 4, 2016 12:06 AM
NC14GT
Jan 22, 2016 08:52 AM
thatmustangguy89
Jan 16, 2016 04:36 AM
Dlouie
Ecoboost
Jan 12, 2016 11:02 PM
