Pulled the trigger on one today!
Originally Posted by SGM SCOTT
(Post 6815707)
So is the basic 2011+ 5.0 passenger side oil separator for $115 bucks all I need?
p |
(Post 6816032)
I have a black jlt from john I got coming...if you all were me, would you still buy a bobs or Moroso? Which??? |
1 Attachment(s)
Originally Posted by FromZto5
(Post 6816117)
Nice! As soon as I get a refund from my jlt back in paypal, I will pull the trigger.
I have a black jlt from john I got coming...if you all were me, would you still buy a bobs or Moroso? Which??? Attachment 192594 |
Originally Posted by lakeguy77
(Post 6816120)
From reading your posts, the bracket on the Moroso might drive you nuts. The can is beautiful. The attachment loop to the bracket is beautiful. The bracket itself is just a carved out piece of raw steel and looks a little messy, and it sits right up on top next to the pretty stock strut tower brace and attaching to the pretty can. I'd gladly pay an extra $25 to have that bracket with either a brushed finish or powdercoated silver to match the STB. I'm not "like that" but I do notice it when I lift the hood. Might steer you towards Bob's.
Btw is the finish on the Moroso a polished or chromed silver? |
(Post 6816124)
Good point. Also the Moroso is also 150 bucks versus 115 from bobs? I would think functionally, both are comparable?
1 Attachment(s)
I currently have a (borrowed-test mule) large body Moroso and I find the drain valve & 90 degree elbow feature most annoying to access due to my large hands. The Moroso supplied orange VINYL cap became a sticky mess as it began to melt from the exhaust manifold heat. My solution was to install a RUBBER vacuum cap, as residual oil will drip from the uncapped elbow. Otherwise, the separator performs just fine and the large body is a nice-to-have feature.
I’ve decided to go with a different Moroso separtor, PN: 85604 as it’s plug & play for the 2011-14 Roush superchargers and sans the drain valve feature. http://www.moroso.com/eb/catalog/navigationPath//%7B35536%7D::Air-Oil%20Separator%20Small%20Body.html?entryId=catalo g.productgroup.&expand=true&menuId=main.menu As lakeguy77 noted, the supplied raw steel bracket finish definitely needs some help in the cosmetic dept. Since Moroso claims it’s made from stainless steel, I’ll try to polish it up and see if I can get a nice shiny finish? Attachment 192593 |
^ hmmmm
given the above 2 posts about the Moroso, I'm thinking of going Bob's. Cheaper, nice mounting bracket, better hoses, easier drain, also air hose from bottom to top, trapping more oil? |
(Post 6816196)
^ hmmmm given the above 2 posts about the Moroso, I'm thinking of going Bob's. Cheaper, nice mounting bracket, better hoses, easier drain, also air hose from bottom to top, trapping more oil?
Originally Posted by silverstate777
(Post 6816157)
(Post 6816196)
^ hmmmm
2 Attachment(s)
(Post 6816263)
What size vacuum cap is that? I'd read about the issues with the plastic cap melting so didn't even put it on, threw it out during install.
Attachment 192586 Attachment 192587 |
got my refund for my jlt oil separator and ordered a new bobs one in silver. Decided against brushed or black or cf or blue. Silver would go well with my boss stb. I also just got the standard kit, strut tower mount, brass fittings, and regular hoses. I can upgrade to colored fittings and a stainless hose in the future.
Originally Posted by typesredline
(Post 6816243)
Yes. Those exact reasons are why I bought bobs. I'm also about 20 min from them so I picked it up and saw the facilities first hand. Impressive to say the least.
I'm torn between Bobs and UPR?? UPR looks nicer but im still deciding. |
Originally Posted by Jazzman442
(Post 6817667)
typesredline, Wow this is a small world. I am about 45 minutes away from Bob's Where in Florida are you? I'm just North of Clearwater. I'm torn between Bobs and UPR?? UPR looks nicer but im still deciding.
(Post 6817667)
My Bob's shipped.... awaiting arrival...
:D |
1 Attachment(s)
My used jlt arrived today. Mounted it as interim until my Bobs arrives next week. Then I'm swapping it.
Then I'm shimmying myself a new setup to move the jlt to the driver side with my own fittings and hoses. |
Driver side is a waste.
And Yes Bob's is the right choice. (Steve is the actual fabricator). Bob, his boss let him use the companies CNC machines hence the name. He is a good guy. I have had mine since he started making them. He had a GT500, sold it and now he has a Lambo. |
Originally Posted by MJJ
(Post 6818134)
Driver side is a waste. And Yes Bob's is the right choice. (Steve is the actual fabricator). Bob, his boss let him use the companies CNC machines hence the name. He is a good guy. I have had mine since he started making them. He had a GT500, sold it and now he has a Lambo.
Yeah, I talked and worked with Steve. Great guy. I went with silver to go with my boss stb. Arriving next week. So not worth doing drivers eh? Hey, where could I get high end fittings and braided or stainless hoses locally? |
(Post 6818142)
Sean what's up sir...
Yeah, I talked and worked with Steve. Great guy. I went with silver to go with my boss stb. Arriving next week. So not worth doing drivers eh? Hey, where could I get high end fittings and braided or stainless hoses locally? Drivers side at least on the GT500 is nothing more than cosmetic and extra weight. I assume similar for the 5.0 but not 100% sure. |
