Oil Filter
Old Sep 28, 2011 | 09:19 AM
blackgt87's Avatar
Oil Filter
I am getting ready to do the first oil change in my 5.0 and I remember reading on here that people upgraded the filter to a Ford racing one but I can't find the thread or remember the part number.
Can anybody list the part number for the stock one, the ford racing one, and maybe some other premium filters.
The 5.0 does not use an 820 right? It uses a shorter one or something?
Old Sep 28, 2011 | 09:25 AM
blackgt87's Avatar
Amsoil recommends a Wix 57502, is that a good filter?
Old Sep 28, 2011 | 09:28 AM
eliyarbrough's Avatar
I've only use Wix filters. That # you listed is what I get.
Old Sep 28, 2011 | 10:16 AM
montreal ponies's Avatar
http://www.wixfilters.com/filterlook...&TempYear=2011
WIX for 2011-12 Mustang GT
Old Sep 28, 2011 | 10:43 AM
blackgt87's Avatar
My local amsoil dealer only stocks 5w30 amsoil not 5w20....I can't decide if I should run that or have him order 5w20
Old Sep 28, 2011 | 11:40 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Wix. Napa gold(made by wix) or motorcraft 820.
Old Sep 28, 2011 | 11:46 AM
Go 5W30 , won't hurt anything and you'll end up with better lubrication.
Old Sep 28, 2011 | 12:14 PM
kylerohde's Avatar
On the oil filter, there's nothing wrong with any of the previously listed options. However, I am partial to K&N oil filters. Why? Because their filter is going to perform as well as any other premium one, plus it comes with a 1" nut on the end, making it much easier to remove than any other filter I've seen, including ones with the nice grippy surface like Purolater Gold.
Here's the right one for the 5.0: http://www.knfilters.com/search/prod...x?Prod=HP-2011
Old Sep 28, 2011 | 12:17 PM
BlackMamba03's Avatar
10w30 would be my choice on oil. In terms of a filter, I'd go with a K&N or a RP one.
Old Sep 28, 2011 | 12:23 PM
blackgt87's Avatar
Anybody here get an engine tick after going to 5w30?
Old Sep 28, 2011 | 12:49 PM
voyager_1700's Avatar
I highly recommend sticking w/ factory recommended oil weights.. high #.. thicker oil..
1st number cold weight, 2nd number warm weight..
Example..
5w20 compared to 10w30
5w Thinner at colder (startup temp) than 10w
20 Thinner at warmer (normal operating temp) than 30
This was another post going around about the TICK noise..
Just my opinion.. but I would DEFINATELY use a FULL Synthetic Oil
Last edited by voyager_1700; Sep 28, 2011 at 12:51 PM. Reason: wasn't finished typing.. UGH
Old Sep 28, 2011 | 03:33 PM
Overboost's Avatar
Wix are the same as Napa Gold filters FYI. One may be easier to find than the other. Definitely a good filter though. I know UnleashedBeast on SVTP posted some recommendations for oil filters, but I don't have it in front of me.
Old Sep 28, 2011 | 03:41 PM
LEwis26's Avatar
I just use the factory ford filter. Easy to get, and inexpensive.
With good synthetic oil in there, and regular changes, I see problem.
Old Sep 28, 2011 | 03:58 PM
I would also stick with ford's suggest weight oil also. And I would go with a longer filter over the shortie if there is a choice.
Old Sep 28, 2011 | 09:10 PM
BarryT's Avatar
What's the general consensus on the appropriate mileage at the first oil change?
Old Sep 29, 2011 | 06:29 AM
blackgt87's Avatar
I'd like to hear this as well.
Old Sep 29, 2011 | 07:30 AM
kylerohde's Avatar
Seems to be around 1,500-2,000 maybe. Sure doesn't hurt to do that as a precaution.
Old Sep 29, 2011 | 09:46 AM
TheReaper's Avatar
I'm changing mine at 6500 miles. I see no need for an early oil change.
Kona Blur's Avatar
I'm going to RP 5w30 in hopes to be rid of my engine tick... I'm also going to use the additive from ford. Still deciding on filter. I'll make the switch this afternoon
Old Sep 29, 2011 | 09:54 AM
blackgt87's Avatar
I thought the recommended interval was 10,000 miles?
Please post the results of that in here!!
