Oil change for phase 3 stage 3 Aluminator?
Old Mar 26, 2022 | 02:03 PM
duzak's Avatar
Hi guys I’m new to the forum, hope all is well.
My father passed away and I inherited his mustang. I have been driving it and at 4800 miles it told me to change oil. I never got to ask him what oil it took because I never was even allowed to drive it.
Any way does anyone know what oil and viscosity it is for the phase 3 stage 3 coyote engine with 675HP and 585 TQ ?
thanks
my guess would be 10W50
Old Mar 26, 2022 | 05:01 PM
Siber Express's Avatar
5W 50 Full Synthetic According to Ford Performances web site about the Aluminator.
1) Technical Specifications M-6007-A50SC Crate Engine: Engine Assembly Part Number M-6007-A50SC Engine Type 5.0L 4V TiVCT – 2011 Mustang Engine Weight 195.5 kg. (431 lbs) Displacement 4.957L, (302 ci) Cylinder Block M-6010-A50L4V Bore 92.2 mm (3.629 in) Stroke 92.7 mm (3.649 in) Firing Order 1-5-4-8-6-3-7-2 Compression Ratio 9.5:1 Maximum rated rpm 6800 rpm Spark Plug (0.032 Gap) M-12405-M50 Crankshaft Forged Steel, Internal Balance Vibration Damper BR3E-6316-JA, Neutral Balance Connecting Rod (14042R-8) Manley Forged Steel w/ ARP2000 Bolts Piston (part # 0930008101) Mahle Forged, 8cc Dish Camshafts Hydraulic Roller Cam Timing Variable Camshaft Duration Int./Ex. Intake: 260°, Exhaust 263° Total Duration Camshaft Lift Int./Ex. Intake: 12mm, Exhaust 11mm Rocker Arm 2:1 Ratio Cylinder Head Aluminum Chamber Volume 54.5-57.5 cc Valve Head Diameter Int./Ex. 37mm (1.45 in) / 31mm (1.22 in) Oil Filter M-6731-FL820 Oil Pressure 80 psi @ 70° F/ 650 rpm Max Oil Temperature 280° F Engine Oil (8.0 qts.) Motorcraft SAE 5W-50 Full Synthetic XO-5W50-QGT or equivalent Engine Coolant Motorcraft Specialty Orange Engine Coolant VC-3-B (US); CVC-3-B (Canada) Max Coolant Temperature 230° F
Old Mar 26, 2022 | 08:11 PM
duzak's Avatar
Thankyou so much !
Old Mar 27, 2022 | 07:39 AM
Originally Posted by duzak
Thankyou so much !
No Problem, that what we are here for to help each other out.
Old Mar 27, 2022 | 11:48 AM
shaneyusa's Avatar
Not sure what your dad may have had in it, but that is what will be what it would have came with.
That car is the ultimate in the Roush line-up. I would love to see some pictures of that beast. Enjoy the car, but make sure you respect the power it has.
Bob D
2012-2013 BOSS 302
16
Mar 17, 2014 07:18 PM
elkk
May 8, 2013 12:02 PM
montreal ponies
Apr 9, 2011 06:37 PM
Den
33
Feb 13, 2008 02:45 AM
islandmustang
V6 Performance Mods
Jun 14, 2005 11:29 PM
