No engine or Computer
Old Feb 7, 2017 | 01:12 PM
morris340's Avatar
I bought a 2010 GT manual cheap without a engine, PCM or key. I can tell the 08-10 engines are interchangeable, they show four different PCMs ( for 2010 GT manual) but I would guess any of them could and would half to be programmed to my car anyway. I guess my question is if I used an 08 GT for a donor car I assume I can't reprogram its PCM for mine? Car is in good shape but with the mileage not lighting up hate spend a ton on it then have 200,000 miles on the car. I assume if I picked a PCM first for it I could be able to get power up to check? Thanks for any help?
Old Feb 7, 2017 | 03:25 PM
awoychosky123's Avatar
You can definitely reprogram the pcm for your car. you will need the vin of your car and the tear tag of a 2010 GT (Going to a dealership and asking to look under the hood might get you that) and then you can punch that into IDS and reprogram it.
Old Feb 8, 2017 | 07:02 AM
I would think he could find a pcm that matched the vin on the car he bought. No program would be needed then.
