No Clock
No Clock
I have 2011 with Nav, I changed the car battery today and everything works fine except the clock. The clock controls are unresponsive and don't light up. I tried master restart and all that still nothing. Thanks
Did you try disconnecting battery, waiting 10 minutes and connect again?
Did you try putting the key in the on position, not starting car, for a couple of minutes to see if that works?
Good luck!
Good luck!
I disconnected the battery for about 2 hours. Reconnected it and still the same. Everything seems to be working except the clock. I can't imagine anything they could have done changing the battery to blow out the clock but leave everything else. I'll try leaving the switch on for a few minutes, it's worth a try. Thanks
Tried that, nothing. Maybe the Nav Unit, or portions of is finally bit the dust. The compass has been unreliable for some time. Didn't bother me much. This inop clock really get under my skin.
Like Father...
I ♥ Sausage
I ♥ Sausage
That's really strange that just the clock would not work.
The local Ford dealer sucks. I need to make an appointment in Greece and have them take a peep at it, and order what ever they need to fix it. While I'm there I'll get the airbag on order as well to satisfy the recall.
Just an FYI: If you're looking for a response directly from Big Poppa, you may want to consider submitting a private message, as his last forum activity was from 3 years ago on 12/26/21...
Otherwise, I would recommend looking under the repair and service section subforums... If interested, I've provided a thread link below...
In the meantime, welcome aboard!
https://themustangsource.com/forums/f804/
Welcome A Code Reader Which Can Check Body Codes Would Be Helpful if You Don't Have One! May Turn Up An Issue. Here is The Audio Information Out Of The Ford Service Manual.
https://themustangsource.com/forums/...5/#post7079681
Some 2010 Audio Info.
https://themustangsource.com/forums/...3/#post7074245
KC
KC
junkman9096
Oct 1, 2022 04:19 PM
