No.8 cylindar code (failure)
I have read lots of info on the No.8 cylindar issue that was sometimes a factor on 11-12 Mustangs with the 5.0 but I can't seem to find any info on if this problem was corrected by Ford in the later 5.0 engines? Was the issue addressed and or corrected?
It was a custom tune problem, by and large, but at first, indeed, some factory tune engines got hit. It was corrected in the factory and the custom tunes, so you don't hear about this anymore.
It doesn't mean it won't happen, for the number 8 does tend to apparently run a little hotter than the rest, if you play with the engine/tune, but it's now a well known, incorporated into the solution, issue, so you probably don't have to worry about it if the engine tune is a newer one.
There was some early factory calibrations that had vulnerabilities... However they were corrected in "2" versions and forward.
Early custom tunes that were based on the SCT file, caused the majority of the #8 failures.
See my post here https://themustangsource.com/forums/...e-look-529745/
-Matt
-Matt
![What](https://themustangsource.com/forums/images/smilies/what.gif)
Read Matt's thread.
Then here's a couple:
Ford changed out the 11/12 pistons for 13 forward. Coated pistons, change in oil control rings & lands, deletion of oil squirters which added 8 HP (1/cyl) for a total of 420.
https://themustangsource.com/forums/...4/#post6280395
https://themustangsource.com/forums/...6/#post6114107
Search is your friend.
TMS links? External links?
I actually was the first blown #7 piston on my 3.7 to report and document the issue. Cost me a fortune to have my #7 piston replaced. Ford denied warranty coverage because they claimed my pony was tuned by the local crack head down my way..
I keep telling people to steer clear of that 4 banger. They gonna have a lot of #5 and # 9 blown pistons. Its gonna be ugly
