Notices
Sponsored By:
Sponsored By:
New 305-HP Engine, 6-Speed Transmission Expected to Deliver 30MPG Highway
Old 12/2/09, 06:17 PM
  #221
RedCandy5.0's Avatar
How is that weight possible? Now we are in Camaro territory so i guess it is a wash then.
Old 12/2/09, 06:18 PM
  #222
metroplex's Avatar
3450 lb is the curb weight for my stripped down 07 GT manual.
The 2010-up add more luxurious items, sound deadening, etc... so I'd expect the weight to go up, not down.
Old 12/2/09, 06:24 PM
  #223
Bigjohns97's Avatar
Man i hope that weight isn't true.
Old 12/2/09, 06:29 PM
  #224
SpOnkey21's Avatar
It isn't. Just look at the manual weight in the spec sheet linked on the previous page. The manual is listed as 250 pounds heavier than the auto. That cannot be true. Auto equipped cars should be just a few pounds heavier. Ford said the Mustang V6 track pack should weigh about 300 pounds less than a comparably equipped Camaro V6, which weighs in at 3,728 pounds. That means you can safely expect the 2011 V6 Mustang to sit around 3,450-3500 and no more.
Old 12/2/09, 06:43 PM
  #225
Captain Spadaro's Avatar
Originally Posted by metroplex
And what's that I see on the Ti-VCT system? A timing belt? LOL. I'm going to stick with timing chains or gears.
No, it uses a timing chain.
Old 12/2/09, 06:55 PM
  #226
David Young's Avatar
Thank goodness for that. I love timing chains. I had a timing "belt" break on a 300 Z, it bent every valve in the engine and put dents on the top of the pistons LOL!!!
Old 12/2/09, 07:00 PM
  #227
Boomer's Avatar
Comeon... the v6 doesn't weigh 3750lbs... The GT probably won't even weigh that much....
Old 12/2/09, 07:34 PM
  #228
ManEHawke's Avatar
An 05 V6 was at 3350, manual. No way sound deadening and a few amenities will add that much. I'm guessing right under 3500 too.
Old 12/2/09, 07:38 PM
  #229
eci
eci's Avatar
Transmission.
Old 12/2/09, 08:02 PM
  #230
ManEHawke's Avatar
Its not the torqshift lol.
Old 12/2/09, 08:52 PM
  #231
Overboost's Avatar
2011 V6 doesn't get a SelectShift transmission. Watch the video on Youtube, they show the auto shifter and it looks the same as the 2010.
Old 12/3/09, 01:44 AM
  #232
1trickpony's Avatar
Has anyone heard is the rearend is a 8.8 or 7.5? I was also curious if the brakes are 11.5 or 12.4 up front? I know the press kit says 11.5 but it also says larger brakes.
Old 12/3/09, 02:43 AM
  #233
metroplex's Avatar
That looks like a timing belt. Notice the cogs and the belt.
Old 12/3/09, 03:43 AM
  #234
WaltM's Avatar
Originally Posted by 1trickpony
Has anyone heard is the rearend is a 8.8 or 7.5?...
I was wondering as well...
Old 12/3/09, 05:19 AM
  #235
Overboost's Avatar
The way I read it was the base V6 has the 11.5", but the Performance Pack has the GT brakes (12.4" IIRC).
Old 12/3/09, 05:21 AM
  #236
mustangman1960's Avatar
6 speed manual transmission
I guess I am going to have to read these press releases more closely because I missed the part about the 6 speed manual transmission.
http://www.autoblog.com/gallery/la-2...mustang-v6/#18
Old 12/3/09, 05:57 AM
  #237
Gordo325's Avatar
looks like it uses both - chain off the crank, belts driving the variable valve timing
Old 12/3/09, 08:13 AM
  #238
PTRocks's Avatar
That's not the 3.7L engine.
This is the 3.7
Attached Thumbnails New 305-HP Engine, 6-Speed Transmission Expected to Deliver 30MPG Highway-v6.jpg
Old 12/3/09, 08:20 AM
  #239
metroplex's Avatar
that looked like a 4-banger, but the cyl head design should be similar. Perhaps they use timing chains on the 3.7L DOHC V6? I know Ford uses timing chains on many of its DOHC engines (modular V8s come to mind).
Old 12/3/09, 09:25 AM
  #240
SuperSugeKnight's Avatar
So is this the V6 6 speed manual?
http://www.getrag.de/en/239
Quick Reply: New 305-HP Engine, 6-Speed Transmission Expected to Deliver 30MPG Highway
