Need Help with Tire size for GT 8.5 Rim
Old Apr 25, 2010 | 07:20 AM
Blueblaze's Avatar
Simplest way I could think of asking the question for 2008-2011 GT
Will the stock GT tires, size 18 x 235 x 50 work on a Ford Factory Chrome 5 spoke rim 18 x 8.5, 50mm offset?
I believe the current 18 inch wheels I have with this size tire are only 8 inches wide.
Considering going with the Ford Factory Chrome Bullitt 5 spoke wheels
Trying to understand if I will need new tires for this with rim.
Old Apr 25, 2010 | 08:50 AM
Ltngdrvr's Avatar
The tires will fit just fine, no problem at all.
Old Apr 25, 2010 | 12:13 PM
WaltM's Avatar
235/50 will be fine. I run 275's on a 9.5 w/45mm offset and it's great.
Old Apr 25, 2010 | 01:27 PM
Dave07997S's Avatar
You can run a 255 width tire like the 2011 V6 PP does on an 8.5" rim, it is the minimum rim width required for a 255 tire. Optimum would probably be a 245 tire. The stock 235's would also work great with that rim width. I just hate the A/S tires that they put on the car.
Dave
Old Apr 25, 2010 | 02:27 PM
assasinator's Avatar
i ordered brembos for just this reason. factory wider rims.
Old Apr 25, 2010 | 02:53 PM
whysoserious's Avatar
The brembo wheels are great, but they really should have been 9.5. Would have given us many more options in terms of tire availability.
14BlackGT
Aug 26, 2015 12:33 PM
whowasthat
Jul 19, 2015 01:49 PM
