Nav system ?
Old Apr 28, 2010 | 07:37 PM
nsthesa's Avatar
Nav system ?
Is the Nav what they call 'text to speech'? i.e. will is say turn "turn right" or "turn right on Smith St."?
The reason I'm asking is that I recently tested a 2010 Taurus with Nav and it was NOT 'text to speech', which was quite disappointing!
Old Apr 28, 2010 | 08:15 PM
pony racer's Avatar
it will say..
"trun right on Main St. in 100'... 50'... 20' ... hey moron you passed the turn i gave you a count down.. now we have to travel 3 miles to make a u-turn so you can try it again.. next time listen to me..", or was that my ex wife?
Old Apr 28, 2010 | 08:17 PM
corvettedreamin's Avatar
Originally Posted by pony racer
it will say..
LMAO!
Old Apr 29, 2010 | 07:07 AM
JScottGT's Avatar
Not only does it have text-to-speach, it also has voice recognition. While driving you can hit the sync button and ask for an address. It's Ford's way of allowing you to still use it while the car is in motion.
Old Apr 29, 2010 | 08:36 AM
RedWings's Avatar
So you can't use the Navigation system's menus while the car is moving? So if I want to change the address or something else I have to stop or use sync?
Old Apr 29, 2010 | 08:56 AM
mupepe's Avatar
I have a question, can I get the electronics package installed outside the factory? like if I don't order it with my car, can I go back to the dealership in like 6 months with 2 grand and get them to install it?
Old Apr 29, 2010 | 09:00 AM
RedWings's Avatar
I don't think they'd be able to install the climate control portion of it.
The Navigation/sync portion could probably be installed but I bet it would cost a lot more than $2k for the dealer to do this.
Your best bet at this point is to just buy it like that from the factory. If your car is already on order, have the order modified. Even if you don't want to roll this extra $2k into the financing, you'll pay more after the car is delivered than you would with $2k + interest.
Old Apr 29, 2010 | 09:02 AM
Overboost's Avatar
Typically, for these kind of systems, they have different wiring harnesses and are built with more parts than you'd think when it comes to the install. You have to get it at the time of purchase or go aftermarket, that's about it.
Old Apr 29, 2010 | 09:07 AM
RedWings's Avatar
I wanted to say the same thing but wasn't sure if it was impossible. My gut would tell me that a lot of required parts that would come from the factory would not be included. So it would be a HUGE project instead of just pulling the old radio and throwing in a new one.
Old Apr 29, 2010 | 09:09 AM
mupepe's Avatar
****. Looks like I might have to have my order modified then. Will that mess up when my car is built? I ordered March 18th but I don't have a VIN or build date yet.
Old Apr 29, 2010 | 09:10 AM
RedWings's Avatar
It could or it couldn't.
If it is something you really want, i'd modify the order instead of just living with it.
Old Apr 29, 2010 | 09:14 AM
mupepe's Avatar
yeah, I'll be doing it. Thanks for all the info guys.
Old Apr 29, 2010 | 09:19 AM
Overboost's Avatar
Plus the additional antennas, power, and sensors to work with the setup you don't see. I found this out after I got a screen to do the nav install in my Speed6, and after pricing out the parts, it was going to be $3000 to get it put in myself. Not worth it IMO, just get it from the dealer if you want it.
Old Apr 29, 2010 | 09:21 AM
And let us not forget that it frees up the power port for a radar detector! (Those equipped with the Safety Warning System, of course.)
Old Apr 29, 2010 | 09:22 AM
Lancel's Avatar
SYNC comes with the Premium models (regardless of if you select the Electronics Packages), so while you don't get the flashy screen, menus, etc., you do still get the advantage of Turn-by-Turn even without the Electronics Package.
This is a fairly amusingly complex process: http://intelematicstoday.com/wp-cont...example_v1.jpg
In short, the nav IS text to speech, but you're kinda text to speech even without the nav.
Old Apr 29, 2010 | 09:25 AM
IT_Guru's Avatar
Wow, 30 to 45 secs. isn't that bad considering how many systems it interfaces with - all over a cell signal.
Overboost's Avatar
Don't forget while this does work, you are using your cell minutes when you do this from a non-EP equipped vehicle.
Old Apr 29, 2010 | 09:38 AM
RandyW's Avatar
Once you are moving, there are things that you are not allowed to do on the screen. Some things you can still do, some you cannot. You wouldn't want somebody driving down the street to be typing an address into the touch screen in their car, would you? That's the reason for the voice activation. I haven't used it myself but from what I've read here and elsewhere, it's very easy to use.
Old Apr 29, 2010 | 10:02 AM
Overboost's Avatar
If you really want to use the screens while driving, then you need to get a LockPick for the system. it allows controls over some of the locked menus.
Old Apr 29, 2010 | 10:11 AM
Lancel's Avatar
I've never heard of it, what is LockPick?
