Low Tire Pressure lights on dash....
Old 10/11/16 | 07:58 AM
JonsMustang's Avatar
Hey all,
So was driving on the weekend during the day. Parked outdoors. All good. Temperatures dropped to 14c / 57.2f ....drove it at night and got a Low Tire Pressure warning. Drove roughly 20km.....still on. Checked tires, no leaks...Checked today, all tires still has air, and same amount it looks like. What gives!??!
Old 10/11/16 | 08:11 AM
SpectreH's Avatar
By checked, do you mean a visual inspection or you actually used a tire pressure gauge to verify air pressure? Lower air temps will lower pressure, and you may now be below the TPS threshold for turning on the light.
Old 10/11/16 | 08:13 AM
Visual inspection. No tire gauge.
Old 10/11/16 | 08:22 AM
SpectreH's Avatar
Then your pressure is low.
JonsMustang (10/11/16)
Old 10/11/16 | 09:14 AM
Thanks! I'll wait till next week. Changing tires to winter mode.
Old 10/11/16 | 09:45 AM
Bert's Avatar
Light goes on when pressure gets fairly low, something like 24 psi . . . so don't wait too long or drive too far with it like that.
Old 10/11/16 | 11:02 AM
I'll give'er some air tonight. Thanks!
Old 10/11/16 | 04:29 PM
bingo.
Check with a gauge and fill 'er up.
Old 10/12/16 | 07:25 AM
This is kind of like my brake light bulb is out thread.
Old 10/13/16 | 05:00 AM
David Young's Avatar
Or like the windshield sprayer won't work because the fluid is empty.
Please invest in a $5 digital tire pressure gauge. I keep one in all my cars glove boxes.
Old 10/13/16 | 07:33 AM
will that fix my brake light??
Old 10/13/16 | 07:44 AM
5.M0NSTER's Avatar
Nope. But fixing your Got Dam #8 will
Old 10/13/16 | 08:00 AM
Coyote5-0's Avatar
Just remember to regularly change your muffler bearings out too. Make sure you use gloves or some other gripping tool, as you don't want to contaminate the bearing with skin oils. It's similar to how you can ruin a halogen bulb by touching it with your bare hands.
Old 10/13/16 | 01:23 PM
I always paint the halogen bulbs with exterior house paint so I can touch them without wasting a pair of those fancy plastic gloves.
Old 10/13/16 | 09:41 PM
Alright. So my Stang came with the tiremobility kit. Used just the air compressor with tire gauge, right back at 35psi on all sides.
Thanks ya'll....
ps. I'll top off my headlight fluids this weekend.
Old 10/14/16 | 04:56 AM
Siber Express's Avatar
Thanks ya'll....
Make sure you use the HID Fluid, the Halogen will not work with the 2013 HID's
Old 10/14/16 | 09:45 AM
kylerohde's Avatar
Thanks ya'll....
Unless it changed from 2011, correct pressure is 32 psi...
Old 10/14/16 | 10:59 PM
TheReaper's Avatar
My door sticker says 35 psi.
Old 10/17/16 | 09:04 AM
Bert's Avatar
plus bigger is always better
Old 10/17/16 | 02:46 PM
That's what she said....
