Live Axle Covered in a bit of oil?
Old Jun 30, 2012 | 11:44 AM
airoscar's Avatar
couldnt find this in the forum...
I found the live axle driver side covered in a bit of oil (not alot, but enough to lubricate your fingers), i reached over to the top section of the shaft, i can feel something like a loose lid on and it seems to be where the oil is coming from, the "lid" does not tighten, it free-spins.
not sure if that's a breather port of some kind, or i just have an oil leak from the live axle?
Old Jun 30, 2012 | 11:51 AM
stang8psi's Avatar
It's the breather valve.. there is a TSB on it.. It was probably just overfilled at the factory! Don't worry.. Just keep an eye on it.
Old Jun 30, 2012 | 12:02 PM
airoscar's Avatar
thanks for the quick response!
they seem to have overfilled my brake fluid too, i get a bit of oil sitting outside of the reservoir under the fill cap...
Old Jun 30, 2012 | 05:15 PM
Cavero's Avatar
You can find posts on this site somewhere, but they basically point to this TSB:
http://kerrymitchell.net/mustang/doc...sb10-03-07.pdf
which calls for this part as a replacement for your rattle cap:
I switched mine out a couple years ago and no more leaks
Old Jun 30, 2012 | 09:16 PM
SD CALSPCL's Avatar
What Cavero said... my valve was also leaking, take it in and get the new, updated model. It took all of 45 minutes for them to replace it, and also change the diff fluid. This is a no cost repair to you. Print the TSB and take it in with you.
Old Jul 3, 2012 | 11:13 AM
2012GTCS's Avatar
Late reply but follow there advice. I did my suspension and saw the same thing (pretty heavy leakage) and was like #%!^*!!^##&$"@!!. I brought it in told them my rear end was leaking from the vent cap and said I "think" there's a TSB (they get their panties twisted if you act like you know their job too much lol) and they fixed it no problem.
***Credit for to the forums cause I posted up just like you did like 2 months ago and guys directed me to the TSB.
Mpaps
Oct 11, 2017 08:06 PM
Evolution Performance
Northeast
Aug 5, 2016 12:46 PM
Fords4Ever
Oct 30, 2015 09:07 PM
M3hunter
Sep 10, 2015 09:26 AM
