Limited slip 3.7L V6 manual transmition 3.31 ratio.
Old May 7, 2024 | 08:56 PM
Hershey's Avatar
Help;
Was jockeying my trailer with my boat on it lining it up to back down the ramp. Not the best ramp. Anyway the driver's side rear wheel started spinning in the loose gravel.
I thought the limited slip differential would not do that. Power would shift to the other wheel.
Boat + trailer ~~ 3,000 lbs. yes I know it is past what the Mustang is rated for, but I only drive 12 miles to the ramp 2 X a year. Spring and Fall.
Car has no problem towing. Have been doing this since 2014.
Hershey
Old May 7, 2024 | 09:25 PM
05stangkc's Avatar
Pm Your Vin and I Can Check Some things For You!
Kc Admin
Old May 8, 2024 | 05:24 AM
Hershey's Avatar
1ZVP8AM5C5213373 I tried to attach the "window sticker" pdf -- but was unable to.
Old May 8, 2024 | 06:33 AM
Bert's Avatar
how many miles on the car?
could be the limited slip is worn out and has gone "open diff" at this point
Old May 8, 2024 | 06:42 AM
Hershey's Avatar
120,000 miles.
I figured . Damm, car is a daily driver. Never driven hard.
Probably cost $$$ to get fixed. But I probably will leave it as it is.
Hershey
Old May 8, 2024 | 06:51 AM
Bert's Avatar
I am not sure if the "problem" you are describing is because the clutch packs are worn out, but it could be. By around 100K miles, my original LS differential was worn out and had gone "open diff" ... but I'm not sure how well they work in gravel when new
Old May 8, 2024 | 10:50 AM
05stangkc's Avatar
That is One Number Short!
KC
Old May 8, 2024 | 01:08 PM
05stangkc's Avatar
These Might Be Helpful!
Ford 8.8 Rear Axle Shop Manual Pdf's, Parts Listing For Clutch Kit & Rebuild Vid!
Diff Clutch Kit!
https://www.fordpartsgiant.com/parts...1z-4947-b.html
KC
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 2, 2024 | 09:37 AM
Hershey's Avatar
Double checked -- # is correct. Tried to attach/insert window sticker ... no luck. Thanks anyway.
matrix
Aug 2, 2016 10:40 AM
Big-D
Jul 16, 2014 08:55 AM
Airwolf
V6 Performance Mods
12
Aug 21, 2005 11:21 AM
dcranford
Jun 12, 2005 05:39 PM
Falchion
Jan 28, 2005 12:44 AM
