LED Light's Stay ON
It wont. To my understanding... on a 100% life battery, over the course of a year it'll eat away at 1-1.5% of it's life.
Edit:
I've had mine in for a few weeks short of 8 months.
Edit:
LEDs will use less than 200mA (normally around 100mA) at full intensity; at 10% brightness (which is generous, it's probably closer to 3-4%), that means it's using around 20mA. Since most batteries are rated at about 400Ah reserve, assuming there are 5 dimly lit LEDs (giving 100mA), an average battery will power those LEDs for about 4,000 hours. That's about 5 and a half months.
So no, I wouldn't worry too terribly about them.
I am curious . . .
How can the LED lights be getting any voltage/current when they are switched off?
Is there not a normal switch in the circuit?
Isn't an open circuit an open circuit regardless of the type of light bulb?
It's entirely possible that there's other circuitry that it's leaking from. Say, the active theft monitors. The current being used for them somehow emits into the LEDs.
I'm totally guessing, but that's entirely plausible, and you all know it.
Unless someone wants to point me to a full Mustang wiring diagram so I can peruse it...
http://en.wikipedia.org/wiki/TRIAC
AH. Triacs. Well, THAT explains it. And the fading trick. I shoulda knew about that, I learned about triacs in my Lutron RadioRA classes. Now the leak makes all the sense in the world.
The thing to do is get slightly 'loaded' led bulbs, so they have enough resistance in them to prevent the leak...
Hey. That brings up a reason for the batteries to die, if there's more of this 'smart' stuff going on.
/Neat stuff.
//Hear RA2's even better.
/Neat stuff.
Even my old '95 SHO runs the door lights through the remote keyless module, which has transistor switching. If you have a regular taurus without remote keyless, then yeah it goes through mechanical switching, but the RKEM was in SHOs beginning 1991... very nearly 20 years ago.
