Keys / Keyless Entry
Old Feb 6, 2010 | 04:42 PM
stangfoeva's Avatar
MOTM Committee Member
gotcha
Old Jan 30, 2011 | 02:34 PM
CowDoc's Avatar
An ancient thread, but I can't resist adding my two cents.
The IKT keys are a pain. They are huge and don't lay well in your pocket. The most annoying thing is that the panic alarm button keeps getting pressed. No I don't wear tight pants! The change and other keys randomly press the panic button. I've had it happen while I was just walking across the parking lot. Worst of all, the IKTs are molded plastic. You can't get to the circuit board to put tape over the switch. Super glue or removing the battery are your only options. PITA.
Old Jan 30, 2011 | 08:21 PM
944withnos's Avatar
I have the same thing happen to my dodge ram key too. It also has the buttons built into the key. It is annoying, especially walking to the window to see who's the idiot with the alarm going off...Ooops it's me! It used to happen often when I first got it...I don't think it is too big of a deal anymore, it hasn't happened in a while. I do take the keys out of my pocket when I can.
Old Jan 31, 2011 | 08:16 AM
RandyW's Avatar
I like that the buttons are in the key but it would be better if they would make it smaller in the future. And maybe they could program the panic button so that it only goes off if you've held it for a full second.
Old Jan 31, 2011 | 08:27 AM
LEwis26's Avatar
Or just get a flip key and be done with it. It will be the first mod I do to my 2012.
Old Jan 31, 2011 | 12:22 PM
WhiteBird00's Avatar
As long as we're digging up ancient threads...
Most basic factory alarms in mid-priced vehicles will trigger the alarm if the door is opened manually without using the remote to disable the alarm. This is by design and is true of Ford, Chrysler, and GM products. The reason is that the alarm is not connected to the door lock or the windows. It is triggered by the same switch that turns on the interior courtesy lights when a door is opened. It has no way of knowing, for example, that you didn't leave your window down and somebody reached in to unlock the door manually or used a slim-jim to pop the lock.
On GM vehicles you can program an 8-second delay if the driver's door is opened manually. This allows you time to get in and turn on the ignition to disarm the alarm if the battery in your remote is dead. In any car, you can avoid the situation by locking the door using the manual lock slide or **** so that the car is locked but the alarm isn't armed.
Old Jan 31, 2011 | 12:39 PM
SoFlo Mustang's Avatar
Not trying to jump thread, but do the V6 Mustangs have remote start?
Old Jan 31, 2011 | 12:41 PM
Optional on automatics only.
Old Jan 31, 2011 | 12:42 PM
Sad face
NC14GT
Sep 10, 2017 04:47 PM
Evil_Capri
Oct 14, 2015 12:18 PM
tang65c
Oct 6, 2015 07:39 PM
Sep 30, 2015 07:02 PM
Sep 8, 2015 10:45 AM
