just wondering about clutch replacement
Old Apr 27, 2016 | 05:38 PM
rick57's Avatar
Why do all the kits come with pressure plates?
do they want new springs put it when you change the clutch or what?
Old Apr 27, 2016 | 08:10 PM
SilrBult's Avatar
It is possible to replace only the disc, but ideally the pressure plate, disc and throw out bearing should be replaced as well as resurfacing the flywheel. The spring in the pressure plate is subject to fatigue and the friction surfaces of both the pressure plate and flywheel are subject to heat checking and micro cracks. The throw out bearing is relatively cheap and since you already have the transmission out it just makes good sense to replace it while everything is apart.
Old Apr 28, 2016 | 12:37 AM
El Coyote GT/CS's Avatar
If you put a straight edge across the face of your old pressure plate, you'll see why it needs to be changed when putting in a new disk. And resurfacing the flywheel is a good idea too.
Old Apr 28, 2016 | 03:52 PM
14Glassback's Avatar
My clutch was replaced under warranty. They had to replace the flywheel also. Ford redesigned the clutch and it was not compatible with the old clutch.
MikeGrush
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
Apr 27, 2016 12:39 PM
Apr 19, 2016 03:15 AM
blipszyc
Apr 14, 2016 09:41 PM
kanine
Apr 12, 2016 03:22 PM
tgarcia77
Apr 12, 2016 10:04 AM
