Just got a 2014 V6 - some questions about it
Old Apr 6, 2015 | 05:15 PM
whowasthat's Avatar
Hello,
i just got a race red 2014 v6 Performance pack with 7000 KMs on it.
i love the car, but i notice that it takes a while to start. is this common?
also, i see a small spot under the that looks like its bubbling. is there anything to slow it down? i was thinking of coating the whole hood with the rust check rust inhibitor. good idea?
thanks for the help
Old Apr 6, 2015 | 06:11 PM
3point7's Avatar
Originally Posted by whowasthat
Hello,
also, i see a small spot under the that looks like its bubbling. is there anything to slow it down? i was thinking of coating the whole truck with the rust check rust inhibitor. good idea?
thanks for the help
1. No it should not take take a while to start. It should start right up. Have it checked.
2. A small spot under what? If you have paint blistering on the bottom of the hood all the rust inhibitor in the world isn't going to help. The hood is aluminum and they have a corrosion issue that is very common. If the car is still under warranty take it to the dealership and they should repair the blistering paint at no cost.
Finally, you indicated that you have a "truck" in the bottom half of your post.
Old Apr 6, 2015 | 06:23 PM
mustangfan410's Avatar
Originally Posted by 3point7
1. No it should not take take a while to start. It should start right up. Have it checked. 2. A small spot under what? If you have paint blistering on the bottom of the hood all the rust inhibitor in the world isn't going to help. The hood is aluminum and they have a corrosion issue that is very common. If the car is still under warranty take it to the dealership and they should repair the blistering paint at no cost. Finally, you indicated that you have a "truck" in the bottom half of your post.
I think he meant trunk.
Old Apr 6, 2015 | 06:38 PM
whowasthat's Avatar
i should have said hood
Old Apr 10, 2015 | 06:11 PM
backin15's Avatar
The V6 should start right up with little drama. You should have the dealer check it as well as the corrosion issue.
Old Apr 10, 2015 | 07:16 PM
tukatz's Avatar
30k miles later my 2014 V6 starts right up and always has.
Old Apr 10, 2015 | 07:38 PM
whowasthat's Avatar
thanks, i will. it takes maybe 1 to 1.5 seconds to start.
Automagically
2012-2013 BOSS 302
37
Feb 19, 2020 09:28 PM
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
scott6809
Sep 12, 2015 11:44 PM
