iPhone music in my base '13?
The iSimple Gateway comes with an iPod/iPhone docking cable and allows control of iPod through the factory head unit.
https://themustangsource.com/f803/oe...-audio-515466/
I bought the iSimple and the SCC1 tuner as a package (for Sirius), but you should be able to find the iSimple separately for under $100.
There's a panel that you can remove from inside the center console area that gives access to your eBrake. Could probably run a cable through there to wherever you need it near the dash.
I looked at that area as well, but to get the cable into the cup holder (which is what Doiz said he wanted to do) area would require drilling a hole. The solution I posted in #20 in this thread gets the cable into the cup holder area without drilling or severely crimping the cable. I just don't know if the 2013 has the same hole in the center console that I used. It did take some doing to get the cable fished into the cup holder area, but it's there now and works fine.
