Installed Magnaflow Street axle backs on the 2014 GT today
Old Nov 11, 2014 | 10:16 PM
Cdvision's Avatar
I finally got around to installing the Magnaflow Street axle backs on my wife 2014 GT convertible. I read pretty much every write up and watched every video on doing the job. I came up with a plan of attack that worked out very good. It took about an hour to do rolling around on the garage floor.
I sprayed all the rubber hangers with some wd-40 then I started off on the drivers side by loosening the muffler clamp bolts to the end of the threads but not completely removing the bolt from the nut. Then I popped the muffler off the rear hanger using a muffler removal tool (well worth the $20 investment).
There are 3 bolts on the drivers side front hanger. I pulled down on the tip of the muffler to make access of the hangar bolt above the muffler easier. I used a offset 13 mm wrench on that bolt until it was out enough to get the 13 mm ratcheting wrench on it. I used a 13 mm ratcheting wrench on the other 2 bolts. Then the muffler drops righ out. I cut the tab that holds the clamp to the muffler with a pair of tin snips. (The clamps have to be re-used with this set of axle backs).
I used the tool to pop the mufflers off the hangar and then bolted the hanger back up to the car.
I placed the clamp on the new muffler and then slid the muffler into the two front hanger rubbers. Once on the front hangers I slid the muffler into the rear hanger. I lined up and held the tailpipe in place while my buddy positioned and tightened up the clamp. Pretty easy task.
Then we repeated the process on the passenger side. There is only 2 front hanger bolts on the passenger side so the job goes even quicker.
Everything lined up really nice. Installing the new mufflers was actually far easier than removing the stock ones.
The sound is great. It is louder and deeper in tone when compared to the stock mufflers and really turns heads when you stomp on the go pedal.
Very pleased with the way these sound.
The hanger tool.
Drivers side muffler installed
Old Nov 12, 2014 | 06:33 AM
JoeMidnight's Avatar
nice! have you done any highway driving yet? any drone?
Old Nov 12, 2014 | 09:57 AM
NacsMXer's Avatar
Looks great, I love those double-walled tips. I bought the same Lisle exhaust hanger tool when I did my Roush axle backs. I love having the right tool on hand to make things easy.
Old Nov 12, 2014 | 10:27 AM
DarrenGT's Avatar
yup those look awesome. See you sometime soon and we can give em a listen
Old Nov 12, 2014 | 08:29 PM
70monte's Avatar
I also have the lisle tool and it makes things a lot easier. Nice looking tips.
Wayne
Old Nov 13, 2014 | 05:46 AM
TripleBlack14's Avatar
I like those tips too.
Any sound clips?
Old Nov 13, 2014 | 04:27 PM
HizliBullet's Avatar
what i want to know is any drone on the highway at 6th gear?
as for sound clip do one driving inside the tunnel coming from white rock
Old Nov 13, 2014 | 04:30 PM
DarrenGT's Avatar
The cassiar tunnel on highway 1 would be safer LOL
Old Nov 13, 2014 | 10:58 PM
Cdvision's Avatar
No highway driving yet.
Maybe on Sunday.
Any sound clips?
Sound clips are never an accurate representation of how an exhaust sounds so I don't usually bother.
Vrrrrrroooommmmm!!!!
In most cases. Lol
Old Nov 13, 2014 | 11:20 PM
DarrenGT's Avatar
Maybe on Sunday.
In most cases. Lol
all 3 of us should rock the pipes through the tunnel on sunday, over and over LOL. although that would be a PITA.
Old Nov 14, 2014 | 10:40 AM
Cdvision's Avatar
Ya that would be fun.
Last night on my way home from picking the Mrs up from the airport had a clown in a V6 Chrysler 300 pull up beside me on Cambie St.
The goof drives beside me for a bit and then guns it and changes lanes in front of me. Not even worth wasting gas on clowns like that.
But if we had ended up beside him at a red light.......heheh
Old Nov 14, 2014 | 10:47 AM
this meme should sum it up
Old Nov 14, 2014 | 10:51 AM
If that happened in surrey it would be 2 brown dudes in that kinda car and it would be their parents'
Old Nov 16, 2014 | 10:09 PM
Cdvision's Avatar
Got to take the GT for a good drive today including a little bit of highway. They sound great at idle, louder and lower...real nice and real nice under normal cruising conditions. No real drone on the highway.The Mrs loves them. Name:  20141116_142514_zpssfecr7dj.jpg
Old Nov 16, 2014 | 11:02 PM
DarrenGT's Avatar
The sound a mustang should make well done!
Andy11859
Which is Better
Sep 10, 2015 12:07 PM
valanahara
Jul 22, 2015 05:13 PM
Kgilly
Jul 9, 2015 01:47 PM
