Improving '11+ GT Suspension - And keeping warranty
For 2011 GT/Brembo package cars, what is the warranty-safe and CORRECT way to improve the suspension with the following goals in mind:
a) Minimum 1" drop, eliminating wheel gap as much as possible while maintaining a slight rake (no "bottomed out look")
b) Make the car handle as similar to a BMW M3 as possible. This means fast damper rebounding and a ride that is not overly stiff yet communicates as much as possible to the driver.
c) Daily driver - car will never see the track.
d) Maintain Ford warranty, if possible.
I would like to be able to drive my car into a Ford dealership and have them perform all the work if possible. I am pretty certain that my goals will require springs, panhard bar, and shocks. I don't require the ability to adjust the shocks. I do not want to spend more than is necessary but I also want to do it *RIGHT*.
SO.....Sam Strano? Anyone else care to chime in? I would like to start a serious discussion about this that we can build up over time so people know what they're getting into before they start slamming their cars on cheapo springs.
![Agree](https://themustangsource.com/forums/images/smilies/agree.gif)
a) b) c) fit my situation exactly, and I'd like d) too if "reasonable" (ie not "way more money for way less product")
Shotzy installed a FRPP handling pack and said that handling was greatly improved.
Has a nice 1" drop. Might be the best solution to cover your a-d requirements?
https://themustangsource.com/f726/gr...g-pack-487391/
Modifications do not automatically void your warranty.
According to the magazine tests, the brembo cars already hold the advantage over the M3 with the only exception being shock rates so install some Koni's and the FRPP 1" drop springs and you should get what you are looking for. The warranty on the shocks and springs will be with the manufacturer of each, on their own, seperate from the car warranty and wouldn't affect the original car warranty.
One of the The FRPP handling Pak's seems to meet your needs here given your Focus on Warranty and Dealer install. It won' be the absolute best or cheapest but it will do pretty much what you want. Do you even have a car yet? My advice is to drive it a bit before you make those decisions.
Steeda Sport springs w/ Koni Sports. (or get the Roush Track Pack coilover kit)
Eibach swaybars & bushings.
Edit: Did not see the "keeping warranty" bit.
FRPP handling pack installed by dealer. Did this on my 06. Worked great. The suspension will be out-of-warranty by the time that stuff wears out, you can step up to some more serious stuff after that if you feel the need.
Koni shocks/struts, new swaybars, panhard bar, and whatever springs meet your criteria, although just the Koni Sports will get you most of the way there, but no drop. Call Sam Strano fr his input.
DO a search on Shotzy's posts for more info.
The FRPP handling pack sounds like a good bet. I do want to maintain Ford warranty on my suspension parts but not if I am seriously compromising. In other words, if there is a much better solution for the same dollar that might not be as warranty-friendly, I'd love to hear about it.
Otherwise I'm going to order this kit on Monday. I just took delivery of my car today and I love it - but this suspension is just far too floaty and vague for my tastes. And the wheel gap....eeegads!
I'm in the same boat... a through c applies to me as well... but I was planning of getting the Steeda UltraLites or Sport springs installed with an Adjustable Panhard Bar. The drop will not be dramatic, getting rid of the wheel gap and Steeda will stand behind their products 100% due to the partnership with Ford.
I think I'm going Steeda on mine...
Get the FRPP kit from CDC if they still have it. Springs, struts, shocks (made by Dynamic, btw)and a sway bar for $350... can't beat that. You'll need the 05-09 tower mounts ($30 each-ish) as well. I'd like to hear how this mod could effect the warranty on any other parts....
![](http://img.photobucket.com/albums/v11/carnut169/alb2/P1080906.jpg)
and can you post a pic of your car
So what warranty is everyone afraid of voiding? Changing suspension isn't going to affect the majority of your warranty, you'll still have engine and powertrain, etc. I think many folks feel that any mod voids all your warranty, the manufacturer has to prove what you did caused the failure. People seem to worry too much.
Does anyone thinking putting different tires on your car will void the warranty of your car? If they aren't tires supplied by Ford than they should, at least according to the fears expressed by so many.
That's not totally true. Adding a CAI (for example) does not void the warranty on your engine unless Ford can show that the mod was the reason for the engine failure/problem.
Putting in ill-designed suspension bits could conceivably put additional wear/tear on the other factory suspension components (not saying it's likely, but it is possible).
I have fought hard in the past against other car manufacturers on warranty issues due to aftermarket parts. I was young and stupid to fight. Because you cannot and you WILL not win that battle with these guys. If you cannot afford to pay for a whole new Ford engine, you shouldn't be running an aftermarket tune. People are far too cavalier about mods, in my opinion. And because I don't want to be responsible for laying out a few grand in cash to fix some damaged control arms, bushings, etc I want a factory-approved suspension kit.
