I now have the imfamous 5.0 engine tick @ 19,650 miles
Old 11/11/15 | 03:27 PM
  #141
PonyMuscletang13's Avatar
Just ordered Amsoil 10W30 & Oil filter. Here's the link I followed on ordering.
http://forums.corral.net/forums/s-19...5l-coyote.html
Trying out different engine oil is one thing, but the way things laid out here must be related to internal engine components. Lifters, Fuel Injectors, Pistons, Rods, valve train, low oil level, oil deposits. Again, I'm not a mechanic.
Found some Interesting reads:
3 Causes of Lifter Tick
http://www.carsdirect.com/car-repair...of-lifter-tick
Why is My Engine Ticking?
http://gobdp.com/blog/engine-ticking/
Still against taking my Engine apart, bad internals or whatnot. But if the noise doesn't go away even after the oil tryouts, I wouldn't have much of a choice. Well except maybe try to live with it. I don't want to, really.
Old 11/11/15 | 04:16 PM
  #142
Last1's Avatar
Thanks for the bit of piece of mind. I am changing back to Motorcraft oil and filter when I go to the dealer on Monday...see if that does anything. I noticed that other people have had the tick that speeds up with a feathering of the throttle like mine. This is what had me the most concerned. I also noticed that my tick is not as loud as many of the videos out there. You can only hear it if you get close to the engine or if it echoes off of another car or highway divider in traffic. But it's barely noticeable. Maybe I had this all along and never noticed because maybe it is more prominent with the brand of oil. I guess I'll find out. Thanks again for the feedback and links.
Old 11/11/15 | 07:52 PM
  #143
14Glassback's Avatar
One of the techs at work did an oil change on a GM SUV. I think it was an Equinox. I did not actually see or hear the car. But immediately after the oil change it was ticking like crazy. They did some research and found that this power train is prone to having oil passages get plugged from pieces of the oil filter. Cheap filter material can circulate in the oiling system and plug the screens in the cylinder heads. Not sure if something like this could also be an issue on the 5.0. But lots of folks mention it happens after oil change. Thoughts?
Old 11/12/15 | 06:51 AM
  #144
Last1's Avatar
I'd just like to add another observation of my particular tick - You can't hear anything when the car is first turned over. There is no tick sound at all. It doesn't start making the sound until the car is fully warmed up.
Old 11/12/15 | 07:13 AM
  #145
Last1's Avatar
This is interesting.
Old 11/12/15 | 08:23 AM
  #146
scott9050's Avatar
Mine has quieted down a lot and I continue to drive it hard at times with no ill effects. I will see if it comes back stronger after the next oil change.
Old 11/12/15 | 08:20 PM
  #147
HizliBullet's Avatar
Originally Posted by SpectreH
Two oil changes with 5W 20 Motorcraft oil (after using Mobil 1 5W 20 for nearly 30,000 miles) seems to have solved my engine tick. The first Motorcraft change did nothing, but after the second change the tick did not come back. I generally use Motorcraft filters, but I have used Wix when they weren't in stock.
I tried that 5w 20 Mobil 1 it didn't work for me
Old 11/12/15 | 08:57 PM
  #148
2011 Kona Blue's Avatar
You would think someone would be able to figure out the cause of this tick, how to fix the tick and how to prevent this tick. Wish I could but I suck! Lol
Old 11/12/15 | 10:42 PM
  #149
SpectreH's Avatar
Mobil 1 is when my tick started. It went away after two Motorcraft changes in a row.
Old 11/13/15 | 05:10 AM
  #150
Last1's Avatar
Mobil 1 is when my tick started. It went away after two Motorcraft changes in a rox.
Motorcraft 5w 20?
Old 11/13/15 | 06:42 AM
  #151
SpectreH's Avatar
Originally Posted by Last1
Motorcraft 5w 20?
Yes, I'm now using Motorcraft 5W20 synthetic blend and tick did not come back after the second oil change with it.
Old 11/13/15 | 06:59 AM
  #152
Last1's Avatar
Thanks. Going back to that on Monday. Crossing fingers...
Old 11/13/15 | 09:00 AM
  #153
SpectreH's Avatar
If the tick reappears after the first change after going back to Motorcraft (mine did), just drive it normal and see what happens at the following change. That is when my did not come back.
Old 11/13/15 | 09:06 AM
  #154
dave07's Avatar
Just give your car the old Italian tune up!!
Old 11/13/15 | 12:59 PM
  #155
kanine's Avatar
I had the tick before my first oil change, and my 2 oil changes after that were with Motorcraft and I still had the tick. I used Mobil 1 with my 3rd, and my 4th change 3 weeks ago, and every time, tick came back loud. I have put about 300 miles on it now, with some hard driving, and the tick has quieted down a lot. It never goes away, but it becomes more sporadic and not as noticeable. The only thing I can say out of this is the car drives fine.
Old 11/13/15 | 03:37 PM
  #156
Last1's Avatar
It's reassuring that your card are fine with this tick. The only thing that really has me concerned is how mine speeds up when I feather the throttle. You can hear it in the earlier video I posted. This only happens after the car has been warmed up. It's quiet as a mouse on startup.
Old 11/13/15 | 04:11 PM
  #157
kanine's Avatar
Yes, it's the exact same thing most of us have, the tick only appears when it's warmed up. It's more pronounced around 1500-2000 rpms when accelerating, and you can hear it bounce off the wall, or other cars when you are next to it. At idle, it comes and goes randomly.
Let else know what your dealer says. I took mine in twice, the first one told me it's "normal" on Mustangs and it goes away after 7,500 miles (yea, sure, okay, never went back there again). The 2nd time I took it to another dealer, they agree it was ticking, but after looking at the car for a week and consulting with Ford, they said they couldn't find where it was coming from, they said they checked everything and said the engine was running normally.
Old 11/14/15 | 12:25 PM
  #158
berzerk_1980's Avatar
I don't know if this contributes anything, but to me it sounds a little like an exhaust leak, backfire, or metal expansion / contraction. Maybe not so much coming from precision engine components.
When I first heard it on my car, I'd have guessed exhaust leak. But then again, I'd just changed the h-pipe.
Old 11/14/15 | 03:33 PM
  #159
Last1's Avatar
Thanks, but the car is only 2 years old and the sound doesn't happen all the time. It started immediately after an oil change. It is clearly coming from the engine. But you're right about the sound being similar to metal expansion/contraction.
Old 12/5/15 | 11:35 AM
  #160
Last1's Avatar
Update: I switched back to Motorcraft a few weeks ago. Ever since I switched back, the tick has been completely gone. It's not quieter or not noticeable- it's gone. I don't understand it, but don't really care. I'm just glad it's gone.
