how to properly break in the new 5.0, mt82 and rear end ?
Old Feb 24, 2012 | 04:21 PM
nickt916's Avatar
I was going to break in my engine by using the link bellow, have you guys found a good way to do best break in for factory engines? does a factory do a proper engine break in before installing into the cars?
http://www.mototuneusa.com/break_in_secrets.htm
Old Feb 24, 2012 | 04:50 PM
RyleyinSTL's Avatar
Just drive the car and check the oil regularly. No break in necessary.
I also highly recommend not taking advice from web pages that look as if they date back to the days of Geocities.
Old Feb 24, 2012 | 04:56 PM
AzPete's Avatar
This is right out of the '11/12 Owners manual. I drove it like I stole it right off the lot.....no issues in 12,000+ miles.
BREAKING-IN YOUR VEHICLE
Your vehicle does not need an extensive break-in. Try not to drive
continuously at the same speed for the first 1,000 miles (1,600 km) of
new vehicle operation. Vary your speed frequently in order to give the
moving parts a chance to break in.
Drive your new vehicle at least 100 miles (160 km) before performing
extended wide open throttle maneuvers and at least 1,000 miles
(1,600 km) before towing a trailer or before performance/competition
conditions. For more detailed information about towing a trailer, refer to
Trailer towing in the Tires, Wheels and Loading chapter.
Do not add friction modifier compounds or special break-in oils since
these additives may prevent piston ring seating. See Engine oil in the
Maintenance and Specifications chapter for more information on oil
usage.
Old Feb 24, 2012 | 09:19 PM
nickt916's Avatar
so basically that link i provided is how it should be done, vary RPMs, vary speeds, shift up and down, put some load on the engine but not to much for the first 1,000 miles.
Old Feb 24, 2012 | 10:34 PM
grabber blue gt's Avatar
Thats basically what I did. Some people beat it right off the dealer lot, but I took it easy for the first 1k and tried to stay under 4k rpm.
But dont forget, CHECK YOUR OIL!!!!! These cars like to burn a bit of oil during break in, some worse than others. Mine only ate 1qt in about 3,000mi but I have seen some report more. Its always safe to just check and keep the level topped off
Old Feb 25, 2012 | 06:44 AM
AzPete's Avatar
....or follow the owners manual......as long as there are no hard, long throttle operations.
Old Feb 25, 2012 | 07:04 AM
Tony Alonso's Avatar
Follow the owners manual.
Old Feb 25, 2012 | 07:49 AM
flySWA737's Avatar
I actually had to drive mine on the highway from 15mi on the odometer. Put 250 miles of varied highway driving that I actually believe helped the breakin. Did some WOT runs when I got her home after the drive as well. Car stopped burning oil pretty early and pulls pretty hard. Gets 21mpg average so I think she broke in pretty well.
Just drive her like normal and give some good revs early on and she'll be fine.
Old Apr 17, 2012 | 08:05 PM
redneb's Avatar
Thought I'd report in here on my experience thus far. 12 GT 6MT built last week of Feb. I have about 1400 miles on the clock. I have been keeping the revs down, no full throttle runs. No long extended trips and keeping the speed varied. I have been checking the oil regularly. The factory fill was only 1/2 way up the dipstick. Today I added 1/2 qt of oil as it was all the way at the lowest mark after being parked on a level surface for two hours.
Old Apr 17, 2012 | 09:55 PM
cinque35's Avatar
thanks for the thread.. just reminded me to check my oil
Old Apr 18, 2012 | 01:39 PM
wanted33's Avatar
Sal, if you need help with breaking yours in, I'm there for ya babe.
Old Apr 18, 2012 | 01:51 PM
Sky Hye's Avatar
Hahah. I'm jealous...
Old Apr 18, 2012 | 01:54 PM
wanted33's Avatar
Yeah, it's sad. The Wifey's hasn't came in yet. I'm desperate.
Old Apr 18, 2012 | 07:00 PM
cinque35's Avatar
can't be long now.. when's your eta?
Old Apr 18, 2012 | 07:24 PM
DCS's Avatar
DCS
...have you guys found a good way to do best break in for factory engines?
ROAD TRIP!
I drove over 1,900 miles in 3 days right after I picked up my car on May 25th.
I highly recommend it.
Old Apr 18, 2012 | 11:55 PM
Sky Hye's Avatar
Hahaha. Pun intended? Hopefully I didn't cross the line on that one.
Old Apr 19, 2012 | 03:37 AM
usage.
Same here at 15k. I followed the manual like you posted and made sure I was takin it to redline at least once/day. Up and out = no laboring to get there. Mixed with mostly 2 lane twisty where I was shifting frequently and mixing speeds, and some freeway - but definitely NOT extended freeway at the same speed. First oil chg @ 700 mi.
Old Apr 19, 2012 | 07:28 AM
fheff's Avatar
My car just turned 600 miles. I'm glad that I read about checking the oil during break in. The last thing I would want is low oil level. I've kept an easy foot on the throttle so far, yet I can tell it's a screamer.
Old Apr 19, 2012 | 11:23 AM
wanted33's Avatar
It was pushed up a week to 05/02. That's not to bad.
No problem my friend. I'm to slow to get it anyway....
Old Apr 19, 2012 | 11:29 AM
LostGeographer's Avatar
Originally Posted by DCS
ROAD TRIP!
Excuse my ignorance, but what app is that?
