How do I get the dangling keys from hitting my legs?
Old Jul 13, 2010 | 01:02 AM
jokerstars's Avatar
I'm 6'1 and no matter how I position the driver's power seat, my keys that are attached to my Ford key ring hit my legs. Wtf!
Also, is it true 3.73 get better city gas mileage than 3.31's?
Old Jul 13, 2010 | 01:11 AM
surf808's Avatar
What I did was put velcro tape for the keys hitting my leg.
Old Jul 13, 2010 | 01:21 AM
jokerstars's Avatar
lol wut
Old Jul 13, 2010 | 03:58 AM
Siber Express's Avatar
One Key in the ignition plus Key ring, no problem.
I am 6'2" and have no problem doing it that way.
Old Jul 13, 2010 | 04:08 AM
OAC_Sparky's Avatar
Easy, live in your car, throw away the rest of your keys. Problem solved.
Old Jul 13, 2010 | 05:09 AM
lots of keys dangling is not good for the ignition. My cure would be get a piece of string and tie the dangling keys to the rear view mirror.
Old Jul 13, 2010 | 06:03 AM
2K3 Mach's Avatar
I would argue that 3.73 its not any worse. Possibly better on certain situations...
I can do 35 mph in 6th gear no problem. Not sure you can do that with 3.31's
Old Jul 13, 2010 | 06:16 AM
corvettedreamin's Avatar
Get one of those multi-key ring links where you can remove the Mustang key from the main key ring. It's a quick-release deal.
Like this:
http://www.buyhardwaresupplies.com/?...Number=5247473
Old Jul 13, 2010 | 06:35 AM
David Young's Avatar
I'm 5'9" and the keys lay on my leg. I've gotten use to it.
Old Jul 13, 2010 | 06:51 AM
DontShoot's Avatar
Like this:
Old Jul 13, 2010 | 07:33 AM
Bert's Avatar
yep, the keys tickle my leg too . . . I try to ignore it . . . if I put the seat back far enough to straighten out my knees for more clearance, then I can barely reach the steering wheel and clutch
Old Jul 13, 2010 | 07:37 AM
Norberd's Avatar
Insert Keys, start car, pull out roll of duct tape, wrap steering coloum with said duct tape, drive away.
Seriously tho, there's a thread about this?
Old Jul 13, 2010 | 07:43 AM
SVTJayC's Avatar
Why did Ford cheap out (as usual) and not put a push button start system like in the SHO?
Old Jul 13, 2010 | 07:44 AM
Adam's Avatar
I notice this too. Super annoying.
Old Jul 13, 2010 | 07:47 AM
Are you all janitors? Why so many keys?
Old Jul 13, 2010 | 07:50 AM
Automagically's Avatar
Why doesn't Jokerstars have any pictures up of his car yet? Did you finally materialize the car in your head since you were thinking about it so much that no matter what car you get in your brain sees a 2011 GT?
The gas mileage in the 3.73 seems unlikely. No real data yet but it doesn't seem like the guys with 3.73 rears get great gas mileage. Driving style, conditions, road rage, this all contributes so maybe thread can be started for fuel mileage vs. the rear end ratios.
Old Jul 13, 2010 | 08:21 AM
Adam's Avatar
Car key
House key
Mailbox key
Work RFID key
Garage door fob
Still hits my leg when driving.
Old Jul 13, 2010 | 08:26 AM
mustang1979's Avatar
Use a carabiner..and once in car, just un clip the Mustang key, insert into ignition and your done. Im 6-4 and find this useful.
Old Jul 13, 2010 | 08:28 AM
Originally Posted by Adam2004
Car key
House key <-- Get a digital deadbolt lock
Mailbox key <-- Uh, you only need it at the mailbox... leave it at home
Work RFID key <-- See first 4 letters... leave it there.
Garage door fob <-- Tuck that away in the center console
See my comments above. I am ever so helpful.
Old Jul 13, 2010 | 08:30 AM
Install an RFID system in your car to bypass the key in ignition all together. Install your own push button start where the 12v adapter is.
While you're at it install a door pop actuator so that when you get close enough the door opens for you. Just options.
