Hood struts and CF or fiberglass hoods. Are they too hard to close?
I have had my CF hood for a month now and have been thinking of buying the MMD or similar, hood struts. The body shop guys said it may be too hard to close the hood though, as it is considerably lighter than the stock aluminum hood. as it is now, the cf hood has to be dropped from alot higher to allow it to catch. no one is a fan of pressing down on the hood to close it lol
Has anyone noticed this?
A fiberglass hood is heavier then the stock aluminum hood. How much lighter is the CF hood then the stock hood? IIRC the stock hood weighs about 20 lbs. or so.
I believe that Redline offers a strut kit for aftermarket hoods, might check them out.
Other than that, you could poke holes in it and put some ugly hood pins in it and do away with the latch.
great thanks for the tip. I'll look into them. If i have to i'll stick with the prop rod. The more I think about it, the stress of a strut system on the sides of the hood towards the windshield might be more of a stress point to consider.
If it were me, I'd keep the prop rod and not worry about the struts. Those hoods are too expensive to risk warping. I'd also go with hood pins, especially if you have any plans of going at high speeds.
I can tell you that ever since i put on those MMD struts on, i haven't banged the hood shut... i'm too scared on denting it as well.
what i've learned is to go with down force momentum. While the hoods coming down, I give it a little bit extra push when its about 6 - 8 inches from fully closing and can manage to close it on the first shot.
Good question and you should be good to go with MMD's struts! If you don't have our discount code shoot me a PM and I'll have it sent over for you asap.
-Alex
If it's WAY too flexible to be pushing down on... wouldn't that mean it's also WAY to flexible to be pushing *up* on, as the hood strut kit would do?
My mind at work, y'all. Laters.
Gigantor
May 11, 2023 07:31 PM
Sep 16, 2015 06:44 PM
