Headlight Question
Old Apr 23, 2014 | 06:39 PM
Mustang33's Avatar
Headlight Question
I recently bought a 2011 gt from a dealership and low beam on one headlight quit working but not the high beam the headlight itself is ford but the wiring behind the light looks real shoddy ele.tape,zip ties,etc and there are HID ballast.First question is this aftermarket second any idea why only high beam works worked fine couple days ago Thanks
Old Apr 23, 2014 | 07:13 PM
5.M0NSTER's Avatar
Probably because it uses a dual ligament bulb. One for low beam one for high/ So one can burn out while the other still works.
Old Apr 23, 2014 | 07:18 PM
Mustang33's Avatar
Funny thing is there is a long and short bulb but both light up on high beam
Old Apr 23, 2014 | 07:27 PM
5.M0NSTER's Avatar
I noticed that and like it a lot. The HIDs are bright, but with high beam it really lights up the road up close and way out.
Old Apr 24, 2014 | 08:23 AM
bones302's Avatar
looks like you got someone's frankenstein project for aftermarket headlights.
there should be only one bulb in the housing (not including the turn signal bulb).
Old Apr 24, 2014 | 10:44 AM
Bucko's Avatar
From American Muscle's site:
The H13 Series Bulbs, also known as 9008 Series Bulbs, are dual filament bulbs featuring both high and low beam filaments in one halogen gas filled glass tube. These brawny bulbs are the latest development in halogen bulb technology. They are featured factory on the new 2005+ Mustang headlights.
Old Apr 25, 2014 | 02:07 AM
rockpolisher's Avatar
The person that owned that mustang put in an aftermarket HID kit. Either the bulb is blown or the ballast is dead. Replace either one or take it to a shop that installs aftermarket HID's. Or if you don't want HID's all together, just take it all out and put the stock bulbs back into the headlight. Btw, the kit you have in there now is made for cars with daytime running lights, that is why there is a long bulb and shorter bulb.
Old Apr 25, 2014 | 04:06 AM
Bucko's Avatar
Please, do all the folks that share the road with you a favor and remove the HID setup, unless you change the headlight housings to those that are designed for HID. Installing HID bulbs in a non HID headlight housing only "splashes" the light, and reduces the headlight amount useable to the driver, and is annoying to those who share the road with you.
Get a set of these: http://www.sylvania.com/en-us/produc...tar-ultra.aspx
Nice, bright headlights, and designed for your current headlight housings.
Old Apr 27, 2014 | 12:05 PM
Mustang33's Avatar
I ditched all the aftermarket wiring back to the factory plug and new h13 bulbs and worked fine at first but after a quick drive it was doing same thing as before high beams only also noticed my fog lights aren't turning on Thanks for the info so far
MustangConvert11
Sep 30, 2015 08:01 PM
