GT manual Shifter issues
Old Jul 22, 2014 | 10:46 AM
Jazzman442's Avatar
Ok everyone. I have read countess threads and coments on the issues with Noisy,Cluncking, notching etc shifting in these cars. The answer seems to be allot of things. Shifter, Bracket trans mount.
Since I'm an engineer no of those answer make any sense. I have had allot of manuals in my day and none of them with these issues?
I was going to buy a SRT challenger and they do not have the issues. I know it is a different and better transmission.
So what is really causing the issue? I would like to fix it but the shifter is not the issue. is it the shifting rods? The transmission it self what?
Mine after about 30 minutes of driving shifts fantastic.
Old Jul 22, 2014 | 11:13 AM
devilcaninex's Avatar
I guess im lucky, I have a 13 GT and stock shifter. Has the 401a shift ball.
I have no problems that people complain about. I have 5k miles on it. No crunching, nothing. I guess the only issue I have seen is once in a while when accelerating hard, its a pain to hit 3rd, but that's only happened a few times.
Old Jul 22, 2014 | 11:56 AM
05PRMTX's Avatar
I am also an engineer. While I agree with you to some extent. There is solid merit to some of these solutions.... The shifter bracket is defiantly an issue. have you looked at it? Its a big piece of rubber with a thin metal band around it. How do you expect that to keep your shifter from torquing around under hard acceleration/shifting? Also, if its not pulling in a straight line on the linkages becasue its shifting around I could see how that could cause some notchiness. The noise/clucking,crunching I would agree has to be something else. Something with the bearings? Linkages? Cruddy syncros?
Old Jul 22, 2014 | 11:59 AM
Mr. V's Avatar
I think what you are saying is agreed upon by most folks. The shifters and brackets aren't really to make it smoother. In my opinion, they are to prevent getting locked out of a gear when driving in a spirited manner. The shifter assemblies that are sold will give you a shorter shift and more positive feel when engaged. The notchiness issue might be helped in your case with a fluid change. Some here have had good luck with that.
Old Jul 22, 2014 | 12:03 PM
Brandon302's Avatar
You should see if you can speak with Pufferfish on bossmustangsonline, he currently has a shifter fix he is working on as well as a trans apart. He has spoken to me about why the trans is so notchy and what not but I cannot remember the exact reason.
Old Jul 22, 2014 | 01:09 PM
Ltngdrvr's Avatar
I also have had no issues with the shift action of my stock shifter or MT82 trans, mine has about 5500 miles on it and I've had it for about 14 months.
Old Jul 22, 2014 | 09:02 PM
05PRMTX's Avatar
Ok so I just replaced the stock bracket with the Barton double post this evening. MY GOD what a difference it made.... Went trearing through some winding roads afterwords and....Not ONE missed shift. Not one crunch or grind. Just solid clicks and gear changes. It was like a brand new transmission. It did add some noise though
Old Jul 22, 2014 | 09:59 PM
Jazzman442's Avatar
What do you mean by noise? NVH or audible noise?
I am trying to find out a way to help the shifting crunch if you will with out adding NVH or Noise?
Old Jul 22, 2014 | 10:56 PM
05PRMTX's Avatar
I mean the NVH is audible if thats what your asking. If you mean can you hear it more, yes defiantly. It completely cured the shifting crunch and missing shifts though. To me its not that bothersome. The added noise is a small price to pay for how much it cleans up the shifting.
Old Jul 22, 2014 | 11:45 PM
El Coyote GT/CS's Avatar
It "sounds" like you're running too much muffler!
Old Jul 23, 2014 | 06:29 AM
05PRMTX's Avatar
Ha! Touche...I am just running axle backs at the moment.
Old Jul 23, 2014 | 06:46 AM
typesredline's Avatar
Originally Posted by Jazzman442
What do you mean by noise? NVH or audible noise? I am trying to find out a way to help the shifting crunch if you will with out adding NVH or Noise?
Another vote for bracket fixing issues. I feel that the steeda red did the same as he is describing. So if you don't want any added noise, that's the way to go.
Old Jul 23, 2014 | 06:56 AM
tbone004's Avatar
NVH is expected when you remove a rubber mount and replace it with a steel bracket.
Getting a little NVH in the cabin is fine with me, plus most of us couldn't hear it over the open Boss side exhaust or Borla Attack axle backs.
I miss the gear whine that my terminator had, it's all the sounds of a muscle car. I don't expect my Mustang to be as quite as a Caddie or Lincoln.
Old Jul 23, 2014 | 07:42 AM
Brandon302's Avatar
Replace the UCA with a poly or spherical piece, the gear whine will be there.
Old Jul 23, 2014 | 03:20 PM
Jazzman442's Avatar
I have read everything about the shifter issue. I understand some of the fixes hear and agree with them. I am still not understanding what the real cause is?
If you look at the bracket the connects the shifter assy to the transmission there is not allot o movement it can have unless the trans bushing is loose rubber? Holding up the back of the shifter housing with a poly mount will help but I am not convinced and by reading most post that is not the Clunky shifting issue?
The feeling that everyone describes and what I have experienced, feels like the shifting rod or something in the transmission is binding.
I would of thought that with all the people and some of which are from Ford would have an answer.
For now looks like I am ordering the bracket.
Old Jul 23, 2014 | 05:08 PM
Way2QWK's Avatar
As I understand, the reason for the shifting problems with the MT82 trans is due to the remote mounted shifter design. It's just not as solid or as precise as a T56 or other direct mounted shifter designs. To much flex between trans, shifter and shift rods. Thats why a bracket the ties all 3 parts together may be the best solution. Im guessing thats what the Blowfish piece is......just my thoughts. This bushing is what Im trying next.
http://www.vorshlag.com/product_info...roducts_id=617
Old Jul 23, 2014 | 06:09 PM
Just speculation. But on the 2015, it uses the same MT-82. Only documented difference Ford has talked about is the shift linkage. So maybe that's the weak point?
Granted, it could be mounted in a completely different way as well.
Old Jul 23, 2014 | 07:00 PM
Jazzman442's Avatar
Isnt this the same part?:
http://www.americanmuscle.com/whitel...-kit-1114.html
I have read that most people that use this complain of allot more NVH.
Old Jul 23, 2014 | 07:01 PM
Jazzman442's Avatar
Now that is what I was thinking is the weak link here is movement. Either in the shifter mounting or the Shift link.
Old Jul 23, 2014 | 08:31 PM
Joeywhat's Avatar
The increase in NVH is negligible in my case (V6, though).
