GT Fog light delete for more airflow- suggestions
Old Feb 16, 2015 | 09:05 AM
MRGTX's Avatar
Yes, I have seen the MMD Fog Light Delete plates...they're fine and look similar to the grille in the Boss 302...which is cool.
If I'm going to pop out the good looking fog lights, I would prefer to gain some cooling by leaving them open..but perhaps with some mesh in there so as to catch rocks, etc...and make it look a bit more finished.
Has anyone done this? What mesh/screen did you use? How did you attach it?
Any suggestions are welcome!!
Old Feb 16, 2015 | 09:18 AM
TheReaper's Avatar
The Saleen grill is the way to go on the 11/12 GT.
Attached Thumbnails GT Fog light delete for more airflow- suggestions-0121121641-02.jpg
Old Feb 16, 2015 | 10:50 AM
MRGTX's Avatar
Thanks! I do like the Saleen piece.
...but for budget reasons and because I like he circles in the fog light positions, I want to see what's possible with the DIY/Screen approach.
Old Feb 16, 2015 | 11:14 AM
Dean Martin's Avatar
Well, I just opted to buy the Boss 302S version with the mesh already installed. Really like it. Maybe consider that and sell your existing?
Old Feb 16, 2015 | 11:33 AM
MRGTX's Avatar
Again...a very nice piece but last I looked, that was over $300.
Old Feb 16, 2015 | 12:04 PM
Sorry, read too fast and missed your budget comment.
I did see someone do what your asking before, but can't find a post.
I can tell you that on the 302S grill the heavy metal mesh just sits behind the openings, and is then wire tied into place thru small holes drilled into the plastic. Tied in 6 places, two top, two bottom, one on each side. Before I installed mine I beefed it up a bit by using some clear silicone on the wire tie points, but on the back side where they are not seen.
Hope that might help some....
Old Feb 16, 2015 | 12:13 PM
2012GT's Avatar
Thumbs up on the Saleen grill. How difficult is the install? I want!!!!
Removing the Fogs getting more air reminds me of a similat mod called Free Ram Air on the F body camaros.
Old Feb 16, 2015 | 12:32 PM
dsp's Avatar
dsp
A lot of Boss guys put screens or something in place of the delete plates. There is a guy on bossmustangsonline that sells a kit. Should work on your grille, it uses the drill and wire attachment method.
http://bossmustangsonline.com/index....80659#msg80659
Some guys get gutter screen from Home Depot, cut it to fit and put that in.
Old Feb 16, 2015 | 01:58 PM
Mike... I was in your same dilemma a year or so ago. I even had a thread on it. I was THIS close to getting the saleen grille. I decided instead to go with COB Halos and had the fogs tinted to complete the look. The research I did showed that the cooling effect from the open fogs was minimal especially in day to day driving. I don't track it, so I wouldn't see the full effect from it anyways.
But if you MUST have the cooling, I suggest going with the Saleen grille. The DIY for the circular openings was something I also considered, but I saw some DIY's that looked terrible and that dissuaded me altogether from going that route.
Old Feb 19, 2015 | 12:31 PM
AMWill's Avatar
Former Vendor
Hey MRG,
Great question!
Although I love the look of the MMD Boss Style Fog Light Deletes
doing something like this DIY sounds like a fun little project.
Although I don't know which materials they used, I have seen it done and it looks awesome!
I feel as if any quality mesh will work as you don't want to take a rock in there!
I'd love to see what you do with this, keep up updated!
-Will
Old Feb 19, 2015 | 04:29 PM
TheReaper's Avatar
It's easy, you don't have to remove the bumper cover.
Old Feb 19, 2015 | 06:33 PM
Getportfolio's Avatar
Thumbs up on the Saleen grill. How difficult is the install? I want!!!! Removing the Fogs getting more air reminds me of a similat mod called Free Ram Air on the F body camaros.
There's a good video on Youtube from brenspeed. I had the grille on my old sixer and loved it.
Old Feb 19, 2015 | 06:36 PM
Sorry friend. Yes you can install without removing but you should. The grille has to be drilled on it's lower portion and fastened with push pins in order to sit flush. It's very difficult to get a drill in there let alone your hands. Too easy to mess up....just take the bumper off
Old Feb 19, 2015 | 06:46 PM
TheReaper's Avatar
I had 3 push pins in the bottom of mine and had no problem drilling with the grille in place.
Old Feb 19, 2015 | 09:39 PM
You rock! I had 3 push pins as well. That really is the way to go instead of the 1 pin that comes in the hardware kit.
Old Feb 19, 2015 | 11:48 PM
SSStang's Avatar
This is what I did. It was free for me. I got the mesh from my neighbor. I had to take the front bumper off to remove the fog lights since I didn't want to cut the brackets but it was easy. This is the only pictures I have right now the car is in storage right now.
Old Feb 20, 2015 | 07:10 AM
dsp's Avatar
dsp
I made my own to look like the stock pattern, just opened up. Also have a set that match the rest of the grille.
Old Feb 20, 2015 | 08:43 AM
looks nice! What did you use for the mesh screen and where did you obtain it from?
Old Feb 20, 2015 | 09:04 AM
dsp's Avatar
dsp
They aren't a screen, I had them done on a 3D printer, they're ABS.
I like the ones that match the Boss grille better. Kind of hard to see in the picture, though.
Old Feb 20, 2015 | 09:14 AM
oh hell Most of us won't have access to that. Although I do know the folks that work in that department, but still. It won't be something the masses will be able to obtain.
