Got d3s bulbs. Now what?
Old Sep 5, 2011 | 08:30 PM
JohnNy5126's Avatar
Can someone please tell me how to change them out? All i know what to do is unscrew the black plastic caps from behind them. I see the plug going in next to it. Do they twist out like h11s?
Old Sep 6, 2011 | 12:02 AM
linelock's Avatar
Just pull it straight out. It's held in by a bunch off metal friction tabs around the edge.
Old Sep 6, 2011 | 09:59 PM
JohnNy5126's Avatar
But tge power plug looks like a seperate area.
Old Sep 7, 2011 | 04:09 PM
linelock's Avatar
Ya there is about 4-6" of slack on the wire so you can unplug it after you pull the bulb.
Old Sep 8, 2011 | 06:26 PM
JohnNy5126's Avatar
The bulb simply wont come out. Holding the ballast and pulling straight back does nothing.
Old Sep 8, 2011 | 10:25 PM
linelock's Avatar
It should pull out but it is pretty tight. It's been about 9 months since I changed mine but I know I had a much harder time getting the new one in then pulling the old one out. Mine was on the passenger side and there wasn't much room. Maybe it's a better job for the dealer. With you supplying the bulb, it should be pretty cheap.
Edit. just looked it up in the online service manual, it says to rotate the 2 locking tabs counter-clockwise and then pull straight back. Sorry I didnt remember that but it was a while ago.
http://iihs.net/fsm/?dir=1020&viewfi...amp%20Bulb.pdf
High Intensity Discharge (HID) bulb
4. Remove the HID bulb access cover.
5. Rotate the locking tabs counterclockwise to release the bulb.
6. NOTE:
The HID bulb is retained by spring tension on all 4 sides of the bulb base.
Remove the headlamp bulb by pulling it straight back.
• Disconnect the electrical connector.
All bulb types
7. To install, reverse the removal procedure.
• For vehicles equipped with HID headlamps, make sure the bulb cover is fully seated.
Old Sep 9, 2011 | 05:03 AM
JohnNy5126's Avatar
Thanks a lot, that did it!
Diode Dynamics
Nov 30, 2021 12:20 PM
fdesalvo
'10-14 Exterior Modifications
26
Apr 5, 2013 09:01 AM
watchdevil
05-09 Exterior Modifications
Dec 10, 2011 06:28 AM
