At the garage, skip shift question.
Old May 18, 2011 | 11:49 AM
Jott's Avatar
Hey quickly, is this the skip shift plug? I can simply unplug this and skipshift will be eliminated?
Many thanks
Old May 18, 2011 | 12:16 PM
Ltngdrvr's Avatar
Nope, doesn't look like the right one.
The skip-shift solenoid is on the right side up near the top at the back of the transmission and the harness plugs directly onto it.
Old May 18, 2011 | 12:20 PM
fdjizm's Avatar
No and please don't pull random stuff off of your new car lol
Old May 18, 2011 | 12:40 PM
hahnsolo78's Avatar
Can someone explain what skipshift does exactly?
Old May 18, 2011 | 12:50 PM
Norberd's Avatar
Under the right conditions it will force the driver from 1st to 4th (6 spd Manual). Most of the time it will just flash a message on the display saying shift 1 - 4 for fuel economy.
It's only forced me into 4th a handful of times.
Old May 18, 2011 | 12:52 PM
AzPete's Avatar
At slow speed acceleration, there is a solenoid that forces you to shift from 1st to 4th...no option. The rpm is normally 1800-2000 and real slow accel. Very seldom hits but when it does, it makes you think you forgot how to shift.
Right side (passenger) upper rear corner is correct location. I unplugged mine and tapped the plugs to keep things clean. Then zip tied the pigtail to another harness.
Old May 18, 2011 | 12:54 PM
corruptor's Avatar
Find the tranny fill bolt. The skip shift plug is 2-3" directly above it. Depress the end of the clip to remove.
Old May 18, 2011 | 01:02 PM
Jott's Avatar
Lol good thing i asked the pros! Thanks
Just got my roush axlebacks in. Couldn't be happier! wow!
Old May 18, 2011 | 02:52 PM
Modshack's Avatar
Gigantor
May 11, 2023 07:31 PM
50Cal
Sep 16, 2015 03:54 PM
