At the garage, skip shift question.
Under the right conditions it will force the driver from 1st to 4th (6 spd Manual). Most of the time it will just flash a message on the display saying shift 1 - 4 for fuel economy.
It's only forced me into 4th a handful of times.
At slow speed acceleration, there is a solenoid that forces you to shift from 1st to 4th...no option. The rpm is normally 1800-2000 and real slow accel. Very seldom hits but when it does, it makes you think you forgot how to shift.
Right side (passenger) upper rear corner is correct location. I unplugged mine and tapped the plugs to keep things clean. Then zip tied the pigtail to another harness.
Gigantor
May 11, 2023 07:31 PM
