Funnel
Old Mar 1, 2015 | 09:09 AM
Kestral's Avatar
Funnel
My 2013 GT I bought used last summer has the no gas cap fuel fill this may be a standard feature of the GT I have no idea but I do see that if you want to add anything to your fuel there is a funnel that is supplied with the car? It seems mine is missing so is this a special funnel or will any funnel work and if not can I order a new one from my dealer?
Old Mar 1, 2015 | 09:19 AM
mustangfan410's Avatar
I found this on amazon. It says it's for a cap less gas tank.
http://www.amazon.com/WirthCo-32855-Funnel-Multi-Purpose-Capless/dp/B00L4816B4/ref=sr_1_2?ie=UTF8&qid=1425226744&sr=8-2&keywords=ford+capless+funnel http://www.amazon.com/WirthCo-32855-Funnel-Multi-Purpose-Capless/dp/B00L4816B4/ref=sr_1_2?ie=UTF8&qid=1425226744&sr=8-2&keywords=ford+capless+funnel
Old Mar 1, 2015 | 09:44 AM
SilrBult's Avatar
I have a '14 GT and like yours, it's capless. Mine came with a funnel. It dosen't really look all that special, but the owner's manual says not to use any others. I used it once to put some fuel injection cleaner in with a fill up. It worked fine, but the opening isn't all that big so I can see where if you had a large cumbersome gas can instead of a small bottle you might get some spillage. There must be some sort of one way valve in the filler pipe that makes this capless system possible. I would think you should be able to get a replacement funnel from any Ford dealer.
Old Mar 1, 2015 | 11:07 AM
14Glassback's Avatar
You can get a replacement. I got one from the local BG guy. That way the factory one is still in the car. The BG funnel is small also. I use a long funnel to funnel into the smaller one. Makes pouring easier.
Old Mar 1, 2015 | 11:42 PM
Fawls's Avatar
Did you check the panel on top of the spare wheel? that's where mine was, if not I have heard they are cheap enough on ebay.
Old Mar 2, 2015 | 04:33 AM
David Young's Avatar
I've had my 2011 v6 since May 2010, i haven't used my 'funnel' yet. Just saying...........................................: )
Old Mar 2, 2015 | 06:34 AM
kylerohde's Avatar
All Fords went to capless fuel filling in 2011...
Old Mar 2, 2015 | 07:47 AM
Jazzman442's Avatar
OK I know I don't Drive mine Allot. Where is this Funnel. I have a 2014 GT?
Old Mar 2, 2015 | 08:27 AM
SplitSecond's Avatar
It will be in the trunk. Mine was optioned with the spare tire, so mine was on a a plastic flap that rested on the spare under the carpet and floor board.
Old Mar 2, 2015 | 08:29 AM
SpectreH's Avatar
My Brembo car has it in the air compressor Styrofoam mount in the spare tire well.
Old Mar 3, 2015 | 07:35 PM
JohnX3's Avatar
Ford OEM Filler Funnel for $5.88:
http://www.ebay.com/itm/Ford-Edge-Explorer-Mercury-Lincoln-Fuel-Gas-Filler-Funnel-Adapter-Tube-OEM-NEW-/321598593990?vxp=mtr
14Glassback
May 20, 2014 11:56 PM
woodzusa
Dec 19, 2013 03:27 PM
2012YellowBoss
2012-2013 BOSS 302
Oct 19, 2011 01:09 AM
tyndallcbr
Aug 16, 2011 09:37 AM
Driver72
Jul 24, 2010 07:11 PM
