first time at the track with the 13 5.0
Old Jul 6, 2012 | 12:58 AM
BOSS302R's Avatar
empty
Old Jul 6, 2012 | 04:49 AM
Old Jul 6, 2012 | 04:53 AM
SilverSkoundrel's Avatar
Can't wait to see what happens after ya get those other parts
Old Jul 6, 2012 | 04:55 AM
t-fatty's Avatar
What a shame Ford didn't put a better shifter/clutch set up in these, your not the first person to have trouble with the clutch.
I'll sell mine before i start taking apart a new car.
Old Jul 6, 2012 | 05:34 AM
3.73-11's Avatar
Nice shifting op imo sg is the best color for making the 2013 mustangs look high class it just really makes the cars appear expensive to me. And just curious but have you got your a/c running while on the track?????? If so they kick you out for that at every track I've ever run at.
Old Jul 6, 2012 | 05:48 AM
UnrealFord's Avatar
My track wont kick you out for AC, they just nicely ask that you please dont use it.
Sucks that your having tranny,shifter trouble. What times did you run.
Love the way you did the filming from different views.
Old Jul 6, 2012 | 10:26 AM
newpony's Avatar
Excuse my ignorance but why?
Old Jul 6, 2012 | 10:58 AM
MikeD73USA's Avatar
Condensation drains from a/c system to the ground, water equals unexpected loss of traction.
Old Jul 6, 2012 | 11:29 AM
newpony's Avatar
^^^ Thanks. That makes a lot of sense. A feel for you guys that go dragging in 90-100F degrees whether
Old Jul 6, 2012 | 11:54 AM
3.73-11's Avatar
^yea what he said they look inside your car before every run and when lining up to run and again where you grab your slips. Every time making sure your ac is off. But basically yes it's because you don't want condensation to leak onto the tires while running on the track.
Old Jul 6, 2012 | 12:41 PM
BOSS302R's Avatar
ill try to work with my ford dealer on this in hope maybe they can do the labor ill buy the upgraded parts, I'm sure BOSS owners down have this problem because their pressure plate and clutch is a stronger set up. Plus i think the weak pressure plate is what probably causes the sinking clutch pedal
i never heard of that, but i see your point, and i forgot to turn off AC couple times, it as just to darn hot!!!! maybe with AC off i would have gotten 13.1 or even 12.9 if everything went smooth.
thank you, 13.3 couple times. I tested tranny the other day at home and it snaps from 1st to 2nd just fine, but after 3-4 times i felt it was starting to grind into 2nd.
Old Jul 6, 2012 | 02:03 PM
SOCOMech's Avatar
Just a heads up but replacing the clutch parts with Boss specific parts won't neccesarily help your problem as Boss's have the same issues as well. From what I understand, there's hasn't been a 100% fix yet but some have used GT500 parts, along with aftermarket shifter, bushings, etc., and have had "better" luck. And I love the Sterling Gray!
Old Jul 6, 2012 | 05:34 PM
BOSS302R's Avatar
i thought a boss pressure plate was stiffer and better clutch wheel??
in this case would it be better to do an aftermarket clutch and pressure plate all together?
Old Jul 6, 2012 | 10:29 PM
96lasersnake's Avatar
I know it is different than the GT's dont know how much better. My 12 Boss pedal stuck a couple times and have read same problems with those cars.
Old Jul 7, 2012 | 06:50 AM
Thomas S's Avatar
Honestly I wouldn't even bother at those temps. You won't get good runs. But I guess some people are more dedicated than i am.
Old Jul 7, 2012 | 04:12 PM
SOCOMech's Avatar
I'm sure a good aftermarket clutch set up would be better than most stock units. I'm coming from a Raptor to a '13 Boss 302, so I'm still learning and researching things myself.
Old Jul 8, 2012 | 03:29 AM
JimmyM's Avatar
Nice
I usually hold the steering wheel at the 7 o'clock position personally
Old Jul 8, 2012 | 04:10 PM
Poisoned Pony's Avatar
Nice, another local guy (I live in Citrus Heights)
good ol' Sac Raceway, prep has been kinda weak lately and at those temps, it's an ice rink!
Old Jul 8, 2012 | 04:47 PM
BOSS302R's Avatar
it was fairly grippy, i think they had a race there jut a week ago so the track was somewhat prepped,... so i heard
Old Jul 8, 2012 | 07:44 PM
July 21st Grudge Night will be packed. Local Ford site is having it's annual cet together prior to the gates opening and there will be quite a few fast street cars as they have a call-out list going.
pats67copo
Repair & Service Help
17
Nov 5, 2025 07:43 AM
5.M0NSTER
26
Sep 28, 2015 07:11 PM
Extremespeedtrackevents
West Coast
Aug 7, 2015 01:41 AM
West Coast
Jul 28, 2015 12:49 AM
Bert
Jul 25, 2015 02:13 PM
