First time oil change, what will I need ?
Old Mar 27, 2013 | 12:36 PM
rm2092's Avatar
No this is not my first time changing oil in a car but my first time in my Mustang.
The reason I ask is all my other vehicles were trucks so I could just crawl under and change the oil with out any ramps or a jack and of coarse I own neither of them so ill need to barrow some from the neighbor down the street. So what will work best for my Mustang a ramp or find a floor jack ? I have like 7100 miles on my car so so I'm going with Amzoil because a freind of mine is a rep for them and I can get the oil and filter at cost.
Old Mar 27, 2013 | 04:24 PM
oil
filter
jack
drain pan
you might need a filter wrench. Sometimes the factoys filters are on super tight.
thats it
Old Mar 27, 2013 | 04:48 PM
AzPete's Avatar
If you rely on the jack only to support the car while under it....add me to your insurance because some day it will get you. I suggest a set of ramps or jack stands.
Old Mar 27, 2013 | 05:27 PM
good call Pete jack stands. I said use the jack because I don't know where the drain plug is and some times you can get more drain oil out by setting the car back down on the ground.
Old Mar 27, 2013 | 05:29 PM
11SHELBYGT500's Avatar
Originally Posted by Glenn
oil
filter
jack
drain pan
thats it
Latex gloves
Tire blocks/wheel choke
Old Mar 27, 2013 | 06:08 PM
Mr. V's Avatar
Latex gloves
The latex gloves is pure genius. I didn't figure that one out for years.
Old Mar 27, 2013 | 08:46 PM
kylerohde's Avatar
You will need:
  • 8 quarts oil of your choice
  • Filter
  • Ramps/jack stands
  • 10 MM socket + wrench for taking off the engine cover
  • Open ended wrench for the drain plug
  • Funnel
  • Gallon size plastic bag (for putting over the filter as you take it off to catch the inevitable oil mess)
It's pretty easy compared to most cars - enjoy!
Old Mar 28, 2013 | 01:24 AM
TommyV's Avatar
I forgot to use the plastic bag trick the first time, big mistake.
Old Mar 28, 2013 | 07:48 PM
GBStang13's Avatar
Do we void our warranty or is there anything wrong w/ changing our own oil? I already hate taking it in because they used a torque wrench to tight my oil drain... GRR
You can also buy MC 5-20w synthetic blend oil 5qt jug for dirt @ WM.
Old Mar 28, 2013 | 08:28 PM
kylerohde's Avatar
Of course not, just keep your receipts and make sure you change it when the car tells you to or before. As for using a torque wrench on the drain plug, that's what you should do - 19 lb/ft.
Old Mar 28, 2013 | 08:29 PM
No, you do not void your warranty for changing your own oil.
Old Mar 28, 2013 | 08:30 PM
Do you use a torque wrench on your drain hole bolt? Lol
Old Mar 28, 2013 | 08:46 PM
kylerohde's Avatar
I sure do. Not sure why it's funny but anything with a specific torque setting on a car should be torqued to that setting.
Old Mar 28, 2013 | 08:51 PM
Because its completely unnecessary
Old Mar 28, 2013 | 08:57 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I've changed oil more times than I can count, on more cars than I can count in my lifetime and have never used a torque wrench on a drain plug and have never had one come out, strip out, or round off.
Old Mar 28, 2013 | 08:59 PM
kylerohde's Avatar
Maybe...but it sure doesn't hurt to take the extra 30 seconds to use the torque wrench and make sure I don't overtighten it.
Old Mar 29, 2013 | 05:57 AM
Stevedotmil's Avatar
You will need 9 QTs if you have the track pack. It takes 8.5 because of the engine oil cooler.
Industrial paper towels
Simple green to wipe up any spills on the ground.
Luckily I was smart enough to epoxy my garage floor when I bought my new house a couple years ago so stuff just wipes right off.
Good luck
Old Mar 29, 2013 | 07:03 AM
rm2092's Avatar
Thanks for all the replays. I guess Ill have my oil next week and I knew I was going to have to buy a new oil pan that will hold 8 quarts. When I had my CBR1000 and ZX10 I always did my own work even oil changes. I hate to pay money for something I can do my self and know its done right.
Old Mar 29, 2013 | 09:32 AM
SennaF1's Avatar
Wow, I feel like an idiot. I've been changing my oil ever since my dad taught me as a little kid, and I've never thought to do that... My least favorite part of the job has always been the filter, because of the inevitable drips/mess.
I take it the Mustang doesn't have a crush washer on the oil drain plug? My last car did, and I was a real bummer to get the oil drained and then realize that I didn't have a fresh washer for the plug.
Old Mar 29, 2013 | 09:38 AM
ace72ace's Avatar
No crush washer. I like the PIG form-a-funnel too. Picked one up from Amazon when I ordered my Fumoto valve.
Fumoto F-106N Engine Oil Drain Valve : Amazon.com : Automotive Fumoto F-106N Engine Oil Drain Valve : Amazon.com : Automotive
http://www.amazon.com/s/ref=nb_sb_ss...tomotive%2C213
