First Issue with my 2011 GT
Old Aug 22, 2010 | 06:10 AM
DontShoot's Avatar
Has 1900 miles on it now. I was driving it around yesterday when I start smelling burning rubber, then squeaking, and a bang, as I lose one of the belts. Turns out it was the air conditioning belt. A Saturday afternoon is one of the worst times for something to go wrong because the service departments all close early. It's kind of funny because I was contemplating taking the car in for service because I noticed that when I turned the air conditioning on it was VERY loud. Could be the compressor failed/seized up on me. On the bright side: I'm up the equivalent of a few horsepower with the air conditioning delete, right?
Old Aug 22, 2010 | 07:27 AM
eric n's Avatar
Sorry to hear you are having an issue this early. Should be a quick fix assuming they can get a new compressor quickly. I'll assume it's the same unit used on previous stangs? Does anyone know for sure?
Old Aug 22, 2010 | 09:23 AM
Scott's Avatar
Did the 2011 5.0 go back to multiple belts instead of 1 belt that turns all the accessories?
Old Aug 22, 2010 | 10:07 AM
DontShoot's Avatar
It looks like the only thing not on the serpentine belt is the A/C compressor. So, two belts. This belt is on the inside of the serpentine belt, so they'll have to take the serpentine off to get the A/C belt on. I really don't think it's a straightforward belt failure... those things are meant to go for many more miles than I have on the car at this point.
Old Aug 22, 2010 | 11:15 AM
montreal ponies's Avatar
Don, did you inspect the belt to see where it actually ruptured.... or you lost it on the side of the road ! I would ( if still in your posession) check where the belt breakage happened since this may well be a sign of a defective belt from the factory. Let us know what you find. Good luck.
Old Aug 22, 2010 | 04:11 PM
BlackOut2k11's Avatar
Since you mention that the AC was very loud when it was on I'm gonna say that the AC compressor seized and snapped the belt.
Old Aug 22, 2010 | 04:17 PM
David Young's Avatar
Old Aug 22, 2010 | 08:42 PM
DontShoot's Avatar
That's exactly what I was thinking. I did inspect the belt, and it looked fine. Honestly though, the way these belts fail, it's hard to tell if it was defective.
Old Aug 22, 2010 | 08:44 PM
Yeah I had an air pump do that years ago on my F150. Bearing siezed. So I cut it out, plugged all the hoses, and threw it away.
Old Aug 23, 2010 | 11:03 AM
Gene K's Avatar
They use two belts but actually they are both serpentine belts. I dont think anyone uses V-Belts anymore.
Old Aug 24, 2010 | 01:50 PM
DontShoot's Avatar
Update: Chuck at Yocum informs me that the AC clutch went. Fused together.
Old Aug 24, 2010 | 02:50 PM
Hope it's just an isolated case, a bit premature for the ac clutch to go.
Old Aug 24, 2010 | 06:06 PM
tom_vilsack's Avatar
be interesting to know if any 2010 owners had this issue....guess on bright side,least it happened early and under warranty...
kponypower
Jun 17, 2020 07:17 AM
Infamous_blackbeard
Oct 8, 2015 10:45 PM
MustangConvert11
Sep 30, 2015 08:01 PM
