Finally test drove a 2011 GT...wasn't that impressed
Old Nov 16, 2010 | 05:44 PM
  #41
yugoboss's Avatar
Like the late Patrick Swayze said, Opinions vary.
Old Nov 16, 2010 | 07:25 PM
  #42
falhulk's Avatar
He also yelled "wolverines" and that makes about as much sense as the crap being stated in this thread.
Old Nov 16, 2010 | 07:55 PM
  #43
Boomer's Avatar
I vould like
to feed yur fingertips
to de wolverines...
Old Nov 17, 2010 | 12:07 PM
  #44
SD6's Avatar
SD6
Originally Posted by PTRocks
You can tell what the car left the factory with by checking the axle code on the door tag.
An explanation of the codes can be found here:
Axle Ratio Codes
The axle ratios are:
• BB - 3.73 ratio, base vehicle with manual or automatic transmission
• CC - 2.73 ratio
• DD - 3.55 ratio with manual transmission
• GG - 3.31 ration with automatic transmission
• YY - 3.15 ratio with automatic transmission
Hmmm I don't mean to hjack this thread but this brings up a whole new interesting question.
The specs for the 5.0GT Convertible are 3.31 gears.
No other option, like everybody says.
However looking at my door tag, it shows DD for axle. So according to above chart I have 3.55's.
Maybe Canadian GT convertibles have diff ratio?
Or maybe it is a function of the Brembo package that gives it diff gears?
Can some other GT Convertible drivers check their door tag?
Old Nov 17, 2010 | 09:56 PM
  #45
StuckInNYForever's Avatar
Manual GT's in Canada come standard with 3.55's. You must have a manual.
Old Nov 19, 2010 | 11:35 AM
  #46
MRGTX's Avatar
Interesting replies. I would have agreed with the op until I got to about 2000 miles. Either the motor finally loosened up a bit, i learned how to drive it... or both....but it feels like a rocket now. I thought my tuned 2009 was qui k but this car would run circles around my old gt.
Old Nov 27, 2010 | 08:04 AM
  #47
Digital_Synapse's Avatar
Originally Posted by Lancel
One thing I've noticed is that if you're trying to pass someone it's much better to drop it two gears lower, not just one. If you're at 2000 RPM, dropping it one gear will at best put it to 3000 RPM. You want to be closer to 4000 RPM. Not joking, it goes alright from 2000-4000 RPM, but around 4500 RPM you can feel it pushing you back in your seat even more.
I thought this same thing and was scared I was gonna over-rev my engine...I said screw it and tried it, definately works.
Originally Posted by Chaotic Bliss
finally found one yesterday. It was a GT vert with 3.73's and California package. Unfortunately I wasn't that impressed.
You drove the wrong one, that's why. I felt that way when I drove the 2010, not a BBP equipped 2011.
Old Nov 27, 2010 | 10:04 AM
  #48
falhulk's Avatar
You dont have to worry about dropping 2 gears. If you are below 60 drop to 2nd. If you are below 75 drop to 3rd. if you are below 100 drop to 4th. That is if it makes sense. You dont want to drop to that gear for 5 mph and have to shift up. Shift to the lowest gear you can at that speed. This transmission requires a diffrent driving style that some people dont get right away. Thats the main reason for the "does not feel quicker then my 92 civic" posts.
samjluck
Sep 17, 2015 10:24 PM
50Cal
Sep 17, 2015 06:43 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
khoy37
Sep 15, 2015 07:10 PM
earl610
Sep 6, 2015 05:48 PM
