Exhaust sound terrible change
Old 3/15/15 | 05:48 AM
Meerology's Avatar
Is there a way to clean out the rust in the muffler?
Old 3/15/15 | 09:18 AM
Blown CS's Avatar
The mesh is part of the baffling which is what helps with the sound of the muffs.
Old 3/15/15 | 09:28 AM
Blown CS's Avatar
Looks like this
Old 3/15/15 | 11:18 AM
Getportfolio's Avatar
Originally Posted by xtc.inc
My roush sounds like garbage now full of water forgot to drill weep holes where should i drill them, near the back of the can before the tip?
Roush started drilling the holes last year. Just look at someplace like AM to see where they drill the holes.
Drill at your lowest point when the cars up. I can't upload pics.
Btw, condensation causes water to build up and the occasional spray in when washing. Yes, it happens to even the most careful. Roush mufflers will rust from the inside out without drainage. Just do a search on the web.
Old 3/15/15 | 07:07 PM
xtc.inc's Avatar
thats garbage man
roush is not a quality piece but they sound the best
mine sounds like a honda civic with a fart can now, its embarrassing
do you recommend drilling additional holes other than the factory ones?
Old 3/15/15 | 07:56 PM
You should have at least one hole towards the tip. I just looked at mine today.
Old 3/16/15 | 05:19 AM
Meerology's Avatar
The flowmaster outlaw doesnt look like a muffler.. so where can I drill a weep hole?
http://www.jegs.com/images/photos/30...389-817511.jpg
Old 3/17/15 | 12:42 AM
El Coyote GT/CS's Avatar
Make the hole at the lowest point of the can. That's usually facing toward the front of the car.
Originally Posted by berzerk_1980
What is this? Like Beverly Hills Cop and the banana?
Vegetables are much better for this application. I prefer using potatoes!
Old 3/17/15 | 03:27 PM
full of water
right by the muffler, not the tip itself. Lowest point of muffler either front side or back side.
Originally Posted by Meerology
How would the muffler be filled with water? First there is the exhaust tip and second wont it just evaporate and go outside the exhaust tip?
Condensation.
thats garbage man
To be honest, that's why I never considered Roush. At the time, there were a lot of rust outs occurring. The quality was suspect.
Yep.
Old 3/19/15 | 12:20 PM
Meerology's Avatar
Thanks for all your replies and help! I found some time and took my car to a garage and put it on a lift. Turns out the clamp that connects the x-pipe to the catts pipe is leaking on both sides, so I took my car to the dealer, put it on a lift and showed them the problem. They are going to replace the clamps and try to push in the pipes closer to each other. I hope that will fix the problem.
Ecostang
11/3/22 09:50 PM
tony2014mustang
8/9/15 04:04 PM
ClayP
8/3/15 10:00 PM
BillyDaKid
V6 Performance Mods
7/15/15 01:50 PM
Quick Reply: Exhaust sound terrible change
