Exhaust sound terrible change
Old Mar 14, 2015 | 08:14 AM
Meerology's Avatar
Hi all, my exhaust sounds extremely different now (Flowmaster Outlaw catback)!! It sounds raspier and uglier than before. The cracking/popping sound after letting of the throttle is completely gone, it just sounds like a drone through the rpm. It was a night and day change, one day it was perfect like always and the next day this all happened.
Ive had my exhaust for barely 9,300 miles and my car has 19,500 miles.
What could be the reason behind that?
Old Mar 14, 2015 | 10:38 AM
Blown CS's Avatar
Have you checked to make sure nothing has come loose causing a leak which would result in less sound traveling through your muffs.
Old Mar 14, 2015 | 10:57 AM
Getportfolio's Avatar
They are supposed to sound better after break in.
That said, I'd refit all connections like CS said.
Undo the clamps and re tighten. Also, make sure you have "weep holes" in the mufflers. Nothing will ruin the sound of a muffler like being filled with water.
Old Mar 14, 2015 | 11:47 AM
Meerology's Avatar
I did check the bolts, they seemed tight and nothing was loose. Maybe the pipes moved apart a bit (where they connect) from speed bumps or something? How can I check if there is a leak and where?
So you recommend I unloosen everything and then put them back together?
Old Mar 14, 2015 | 12:00 PM
Originally Posted by Meerology
I did check the bolts, they seemed tight and nothing was loose. Maybe the pipes moved apart a bit (where they connect) from speed bumps or something? How can I check if there is a leak and where? So you recommend I unloosen everything and then put them back together?
Yes. Or just re tighten.
Betting money you have an exhaust leak in your clamps. No biggie and an easy fix.
Old Mar 14, 2015 | 12:40 PM
Meerology's Avatar
Alright. Thanks for your replies
Old Mar 14, 2015 | 12:41 PM
Meerology's Avatar
Is there a way to check for any leaks before I start unbolting things?
Old Mar 14, 2015 | 12:45 PM
rmurer's Avatar
jack the car up, use jack stands and wheel chucks then start her up and get under the car.
use your hand around the joints and see if there is any air being pushed out.
Not the ideal way but its what i would do.
Old Mar 14, 2015 | 01:07 PM
Meerology's Avatar
Thanks for the tip, Ill do that probably this week. What if I couldnt feel any air being pushed out, any other reasons why this could happen to my exhaust ?
Old Mar 14, 2015 | 01:13 PM
Do you have weep holes in the mufflers and tips?
Old Mar 14, 2015 | 01:29 PM
Meerology's Avatar
I dont know. Arent these to allow water to come out?
Old Mar 14, 2015 | 01:54 PM
Yes there should be one tiny hole in each muffler to drain water out.
Old Mar 14, 2015 | 11:13 PM
Meerology's Avatar
If there wasnt should I drill a small hole?
Old Mar 15, 2015 | 02:18 AM
El Coyote GT/CS's Avatar
A 1/16" hole at the low point of the can should be sufficient.
Did you look inside to see if somebody stuffed your pipes?
Old Mar 15, 2015 | 03:07 AM
xtc.inc's Avatar
My roush sounds like garbage now
full of water
forgot to drill weep holes
where should i drill them, near the back of the can before the tip?
Old Mar 15, 2015 | 04:06 AM
berzerk_1980's Avatar
What is this? Like Beverly Hills Cop and the banana?
Old Mar 15, 2015 | 04:29 AM
Meerology's Avatar
Hahahaha
Old Mar 15, 2015 | 04:30 AM
Meerology's Avatar
How would the muffler be filled with water? First there is the exhaust tip and second wont it just evaporate and go outside the exhaust tip?
Old Mar 15, 2015 | 04:31 AM
Meerology's Avatar
full of water
How did you find out theyre filled with water?
Old Mar 15, 2015 | 04:46 AM
Meerology's Avatar
I did look inside and found something that looked odd. I posted some pics but I dont know how well you can see it. Basically down the muffler where it curves I saw something might be blocking or just there for some reason. It looked like some sort of mesh (or maybe it seemed mesh like from the light ) but I am sure there is something in both mufflers. Should I try poking it and see what happens?
Attached Thumbnails Exhaust sound terrible change-img_3646.jpg   Exhaust sound terrible change-img_3647.jpg   Exhaust sound terrible change-img_3648.jpg   Exhaust sound terrible change-img_3649.jpg   Exhaust sound terrible change-img_3650.jpg
