Engine cut out under Acceleration
Old Oct 15, 2012 | 12:56 PM
Kgilly's Avatar
So this past weekend I come off the interstate and jump on it in 1st gear then hit 2nd and then 3rd and all of a sudden the engine dies out at about 6000 rpm (like it was bogging down) for about a second and then is fine. This is now the 3rd time this has happened, anyone else experience anything like this?
2011 Premium GT, 400 A, Performance White, MT82, Airaid CAI, JLT oil separator, GT500 axle backs, BMR panhard bar, 35% window tint, side window louvers.
Old Oct 15, 2012 | 01:01 PM
Wander's Avatar
Well I have a 2008 GT but that happened to me. Would run fine until I got on it. Turned out to be bad gas, really. Has not happened again.
Old Oct 15, 2012 | 01:15 PM
Kgilly's Avatar
thx, someone else mentioned the bad gas issue, I use 93 octane all the time, but maybe the brand..
Old Oct 15, 2012 | 02:05 PM
GreenCars's Avatar
I have had this on my v6 as well, while getting on it well it seems to have a slight throttle lag for a second or two tell I push threw it. Does not happen on BP.. But has happened on Shell.
Old Oct 15, 2012 | 02:34 PM
GRN 5OH's Avatar
I've had mine cut out on me a few times.........at 7k RPM!
Old Oct 15, 2012 | 05:01 PM
2012WhiteGT's Avatar
Was it bucking or just felt like it lost power? Is it possible you were spinning the tires or rolling side to side? The traction/stability control is pretty aggressive in the normal setting and will retard engine power a huge amount. The car feels like it's falling on its face when this happens.
Old Oct 15, 2012 | 05:32 PM
Siber Express's Avatar
What he said.
Old Oct 15, 2012 | 08:14 PM
Cobrakev's Avatar
Mine did this to me yesterday. Was getting on the interstate, never went over 4000rpm. Check engine light started to flash, but never stayed on. Power dropped off as soon as the light began to flash. After about one min, the light stopped flashing and power came back. I don't know if a flashing light will save a code on the computer. Still looking that one up. No mods to the car other than GT500 mufflers.
Old Oct 16, 2012 | 05:57 AM
Kgilly's Avatar
The TCS light didn't come on that I noticed?, but it did feel like it just fell on it's face for about a second then came back on after I let up on the gas slightly.
Old Oct 16, 2012 | 06:52 AM
2012BLKV6's Avatar
definitely sounds like TC
Old Oct 16, 2012 | 07:14 AM
wheelman's Avatar
Yeah, turn off tc or increase RPMs.
Old Oct 16, 2012 | 08:11 PM
Mickstang's Avatar
Could have been a piece of crud hung up in an injector, I suppose.
Old Oct 17, 2012 | 08:47 AM
I never notice the light, either, but what your describing is definitely the stability control and is totally normal. Our cars spin a lot more than we realize, and even if they're not spinning much, if there is any side to side motion the stab control will retard the power. There's a left hand turn I make all the time onto a country road with nothing but fields on either side, so I take the opportunity to let her have it every time. The road pitches left and then back right. It will trigger the stab control every time in normal mode and the car will fall on its face when I shift from 1st to 2nd.
Try sport mode. Hit the traction control button 2 times quickly from a complete stop or nearly stopped. It will tell you the sport mode is engaged in the message center, and the TC off light will illuminate. It's much less aggressive in sport mode but will keep you from getting in too much trouble. Turning it completely off by holding the button down for 6 seconds is the most fun, but be careful. It will bite you really quick if you're not careful.
Road_Runner
Sep 2, 2024 04:46 PM
Rando
Sep 30, 2015 12:28 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
Sep 8, 2015 10:45 AM
