Does the 5.0 need warming up?
This is the skinny. Today's modern engine is designed to be started when cold. That being said its best to wait 3 seconds or so before pulling away. Excessive idling is also bad. It just causes fuel to wash down the engine oil. You're best bet is to start it, let it idle for 30 seconds then drive it. This doesn't mean to hammer the car. That's never good to do until it reaches operating temperature. Mostly because our aluminum engines grow a lot when heated. And it's always best to beat on an engine once all materials are fully heated.
This is what I normally do, and I don't hammer it until it's up near or at normal temperature. I figure by then everything has had time to warm up.
1-2 two minutes is a VERY long time to let a car sit and idle before being able to drive it. Are you literally waiting 1-2 minutes? The RPM on my '13 GT drop after 10-15 seconds. If yours is idling that high for two whole minutes, something might be wrong.
At least the 5.8 has no traction problems until it is warmed up...and you can stomp on it.
Excessive idling as mentioned before is actually worse for the engine than taking it easy and drive shortly after startup. Once fully warm, enjoy.
LEXiiON
LEXiiON
Most of the "warming up" advice comes from those of us who had carburetors and chokes. Trying to drive off in the cold before choke started opening up generally resulted in some not-so-fun bucking.
If you keep your oil changed, you shouldn't have to worry about waiting long on circulation either. Even in -40. As most people mentioned, once start-up idle drops, you should be good to go.
As for the OP saying their sometimes bucks, it is more likely that you are being overly cautious with the gas pedal and getting near stalls. I've had this a few times after pulling out of the parking lot at work which involves an annoying speedbump I have to crawl over.
I remember reading an article in Popular Mechanics by a researcher at the Argonne National Laboratory who was talking about fuel wash in terms of cold weather idle conditions. It isn't until the engine gets up to a certain temperature that the excess gasoline vapors actually get burnt off since the A/F ratio will become rich when it is cold. I try to wait 30 or 45 seconds and then off I go. Of course this is much different if you have forged internals though.
3 floors down. I usually start the car with my remote starter, so by the time I reach my car, plug in my dashcams...it'll be over 1min of idling
That test engine was probably had a carburetor and points ignition.
Fuel wash (a condition where fuel makes its way past the rings and removes oil from the cylinder walls) is nor really as big an issue with today's modern engines and tight tolerances.
My guess would be that you are much more likely to have a "fuel wash" condition with the car idling in the driveway for 10 minutes while you wait for it to "warm up"...
At its basics, it is when fuel gets on the cylinder bores and will "wash" off the film of oil on the cylinder bore which protects and lubricates the bore from the piston and rings sliding up against it during travel.
Originally Posted by ford20
Pretty sure I said that haha.At its basics, it is when fuel gets on the cylinder bores and will "wash" off the film of oil on the cylinder bore which protects and lubricates the bore from the piston and rings sliding up against it during travel.
