Display low for select shift
Old Jul 10, 2014 | 06:16 PM
Blown CS's Avatar
Curious if any of the other auto owners have issues with their selected gear display being low when in select shift. As you can see by the picture part of the 2nd is cut off and its the same for the other gears. Also, at times seems my display is crooked when my OCD kicks in.
Attached Thumbnails Display low for select shift-2014-07-06-18.19.48.jpg   Display low for select shift-20140702_173726.jpg
Old Jul 10, 2014 | 06:22 PM
tukatz's Avatar
I don't have that problem. Have you tried it with other info in the main part of the display? I can't think why that should make a difference, but you never know.
Old Jul 10, 2014 | 06:40 PM
TheReaper's Avatar
Here's mine in Sport mode.
Old Jul 10, 2014 | 06:52 PM
=HYPERDRIVE='s Avatar
From what I can tell, I think your LCD screen inside the instrument cluster is not aligned and it pitched at an angle, might want to go see a dealer, and get it fixed.
Old Jul 10, 2014 | 07:27 PM
Blown CS's Avatar
Thanks reaper, yours definitely looks more squared up than mine.
I need to keep a list of items before I take it to the dealer. Im sure they will be pleased with the blower. Lol
Old Jul 11, 2014 | 04:45 AM
MADSCOTSMAN's Avatar
I wish it would display what gear the car is in currently when you move the selector to "S". Would make it easier to avoid downshifting too far (other than using the tach which is also affected by engine braking). I wouldn't mind actually seeing what gear the car is in when it is shifting itself in "S" as well?!?
Old Jul 11, 2014 | 11:41 AM
RacerX27's Avatar
Use the 2 black 'tabs' behind the wheel to center the wheel. Use the wheel when centered to center your sight picture. If you have the wheel correct, the display will now look 'centered' and rotated correctly.
Ford did a great job creating an optical illusion with the LCD display.
I took mine completely a part and found out there isn't any way for it to rotate and be mounted incorrectly. lol.
There is a mask on the overlay rings that may be out of place.The assy just pops off, pull on the rings with the wheel down out of the way. Easy as pie.
Old Jul 12, 2014 | 12:21 PM
Blown CS's Avatar
I pulled the front of the instrument panel and their is not anything to adjust. At some point I might make a dealer visit.
Old Jul 12, 2014 | 08:40 PM
RacerX27's Avatar
Looks like my LCD panel is place exactly like yours. If I had an automatic I suspect I would see the numbers cut off also.
Old Jul 12, 2014 | 09:03 PM
typesredline's Avatar
Hmm. I wonder if maybe the black part under the screen isn't straight. If you look at the "door ajar" box, in the pic at least, it's straight across the top.
Old Jul 13, 2014 | 04:36 AM
dmhines's Avatar
The guage overlay is all one piece with a cutout for the LCD. my guess is the LCD is defective or not properly aligned in the cluster. I think the dealer would need to replace cluster to fix it.
Old Jul 13, 2014 | 08:38 AM
Yea either its the overlay that is not aligned properly, or its the 4" LCD that is not aligned. Get the dealer to fix it or replace the cluster.
Old Jul 13, 2014 | 11:44 AM
jim010's Avatar
When I changed my overlay, I noticed that the gear selection was also cut off. I had to take it apart again and align it better to see the gear number.
You could do this yourself, if you are comfortable with pulling the needles off.
Old Jul 13, 2014 | 12:10 PM
Blown CS's Avatar
I changed the gauge faces on my 91 by using the fork method to remove the needles. How do the newer needles come off?
Old Jul 13, 2014 | 12:26 PM
jim010's Avatar
I used a butter knife and made sure I pulled straight up. Aligning them again was a pain.
You could then see if the screen was in there straight.
Another option is to trim the bottom of the window so you can see the gear number.
Old Jul 13, 2014 | 01:04 PM
dmhines's Avatar
I swapped my overlay using a teaspoon on each side of needle. Let's you pry up evenly. There are alignment notches so the overlay is not very adjustable.
Old Jul 13, 2014 | 03:16 PM
Blown CS's Avatar
Thanks guys. I will have to give it try when I get time. Im not a big fan of the dealer working on my car for minor things since I usually find faults in their work.
Old Jul 17, 2014 | 09:37 AM
FordService's Avatar
I recommend you guys bring your vehicles in to your dealers as soon as possible and let me escalate this for you. Please PM me with your VIN, dealer, mileage, full name, and best daytime number.
You can schedule an appointment online here.
Deysha
jim010
Jun 24, 2024 04:23 PM
Gigantor
May 11, 2023 07:31 PM
trackpack13gt
Jul 25, 2017 05:29 PM
Jul 8, 2016 08:53 AM
