Digital speedometer on 5.0 (wow)
This has been around apparently since 1999.
There's this topic on it as well, along with some pics.
https://themustangsource.com/f726/st...484216/index2/
You can also monitor speed info from a scangauge as well as all this other stuff. You can have 4 points of data up at any one time. I've run these for years on my cars.
TPS: Throttle position sensor 0-100%
fIA: Intake Air Temps (Temperatures at the intake manifold)
fWT: Coolant water temperature
HPR: Horsepower (Looks to be pretty accurate from initial runs on several cars)
VLT: System Voltage
IGT: Ignition timing (advance)
LOD: % Power request
Closed/Open loop: Fuel management and transition point from O2 control to WOT
STF: Short term Fuel trims (Idle % on Block 32)
LTF: Long term Fuel trims (Partial throttle on Block 32)
OX1: #1 O2 sensor output, 0-100
OX2: #2 O2 sensor output, 0-100
MPH: Digital speed reading from Speed sensor
RPM: Digital RPM’s
MPG: Miles per gallon
GPH: Gallons per hour
Trip Data: Fuel economy, Fuel used, Distance, drive time, Avg. speed,
Distance/time/fuel to empty, ETC.
Scan Tool: Code reader and eraser, Readiness test, Turn off CEL’s
I usually monitor fuel trims and temps constantly
VLT: System Voltage
RPM: Digital RPM’s
![](http://images49.fotki.com/v1489/photos/5/7305/7450345/IMG_1438-vi.jpg)
Did this before leaving for work today. It gave me a better idea of what the stock speedo is reading. Before I thought the speed I was going was just to the left of the needle. It is actually to the right side.
This digital speedo trick, can I set it and forget it, or do I have to do it every time I fire up the car? If it's the latter, I'd rather buy an Aeroforce Interceptor gauge and save myself the trouble.
Since it's a diagnostic mode I assume it resets when you remove the key.
Mine reset when I stopped, pulled the key and restarted. I also noticed that once I cycled through everything to get to the speedo, it stayed there. Couldn't get it it to change until I stopped/started.
I held the right 2 buttons (can't remember them off the top of my head)
and it went into a mode that showed ROM level and CRC #s
and something labelled FINAL YEAR.
DEFTINATELY not the right mode on my 05
Does this work on 05-09? just tried holding reset and turning the key to the on position (without starting) I got about 5 screens, rom version, serial#, final date, test display, crc ID, etc.. nothing about the engine or speedo.
