Digital speedometer on 5.0 (wow)
Old Aug 3, 2010 | 12:57 AM
VirginiaDrifter's Avatar
This was posted on AFM.
http://www.allfordmustangs.com/forum...ustang-gt.html
Old Aug 3, 2010 | 05:38 AM
RedWings's Avatar
Going to try this out
Old Aug 3, 2010 | 06:15 AM
LinT's Avatar
thats pretty cool! So just hold down the 2 right side buttons (setup and reset i think) while you start the car. Then "reset" to cycle the options. It worked perfectly for me!
Old Aug 3, 2010 | 07:09 AM
2010MustangGT's Avatar
This has been around apparently since 1999.
There's this topic on it as well, along with some pics.
https://themustangsource.com/f726/st...484216/index2/
Old Aug 3, 2010 | 07:24 AM
Modshack's Avatar
You can also monitor speed info from a scangauge as well as all this other stuff. You can have 4 points of data up at any one time. I've run these for years on my cars.
TPS: Throttle position sensor 0-100%
fIA: Intake Air Temps (Temperatures at the intake manifold)
fWT: Coolant water temperature
HPR: Horsepower (Looks to be pretty accurate from initial runs on several cars)
VLT: System Voltage
IGT: Ignition timing (advance)
LOD: % Power request
Closed/Open loop: Fuel management and transition point from O2 control to WOT
STF: Short term Fuel trims (Idle % on Block 32)
LTF: Long term Fuel trims (Partial throttle on Block 32)
OX1: #1 O2 sensor output, 0-100
OX2: #2 O2 sensor output, 0-100
MPH: Digital speed reading from Speed sensor
RPM: Digital RPM’s
MPG: Miles per gallon
GPH: Gallons per hour
Trip Data: Fuel economy, Fuel used, Distance, drive time, Avg. speed,
Distance/time/fuel to empty, ETC.
Scan Tool: Code reader and eraser, Readiness test, Turn off CEL’s
I usually monitor fuel trims and temps constantly
Old Aug 3, 2010 | 07:30 AM
RedWings's Avatar
Did this before leaving for work today. It gave me a better idea of what the stock speedo is reading. Before I thought the speed I was going was just to the left of the needle. It is actually to the right side.
Old Aug 4, 2010 | 11:15 AM
Mossberg's Avatar
I think I did this years ago with my 02 GT. Very useful info.
Old Aug 4, 2010 | 11:19 AM
Overboost's Avatar
Typical rule of thumb is that the physical speedo reads ~ 2mph higher than actual. This can be confirmed via a GPS unit as well.
Knight's Avatar
Needs to be more Astony
Yeah all this was on the 1999 and up.
Old Aug 4, 2010 | 12:53 PM
20115.0's Avatar
yup did this on my truck before lol pretty cool to show off that you have a digital tach as well
Old Aug 4, 2010 | 02:35 PM
ferrarimanf355's Avatar
This digital speedo trick, can I set it and forget it, or do I have to do it every time I fire up the car? If it's the latter, I'd rather buy an Aeroforce Interceptor gauge and save myself the trouble.
Old Aug 4, 2010 | 02:46 PM
Adam's Avatar
Since it's a diagnostic mode I assume it resets when you remove the key.
Old Aug 4, 2010 | 05:59 PM
wannabe's Avatar
Mine reset when I stopped, pulled the key and restarted. I also noticed that once I cycled through everything to get to the speedo, it stayed there. Couldn't get it it to change until I stopped/started.
Old Aug 4, 2010 | 06:57 PM
montreal ponies's Avatar
Wish the SCT programmer could take care of that option to stay on at all times.
Old Aug 4, 2010 | 10:27 PM
Fazm's Avatar
man i could not get this to work on my 05, 08, or 09 lol.
Old Aug 4, 2010 | 11:06 PM
Boomer's Avatar
I held the right 2 buttons (can't remember them off the top of my head)
and it went into a mode that showed ROM level and CRC #s
and something labelled FINAL YEAR.
DEFTINATELY not the right mode on my 05
Old Aug 5, 2010 | 02:09 AM
Thomas S's Avatar
Same here. Never did get the speedo.
Old Aug 5, 2010 | 05:54 AM
fdjizm's Avatar
Does this work on 05-09? just tried holding reset and turning the key to the on position (without starting) I got about 5 screens, rom version, serial#, final date, test display, crc ID, etc.. nothing about the engine or speedo.
Old Aug 5, 2010 | 07:23 AM
rumdawgg's Avatar
Tried in my '05 last night - no speed or engine info...just the ROM and serial stuff.
Old Aug 6, 2010 | 06:54 AM
fritzOSU03's Avatar
I tried this on my '08 a few months back and got nothing but I get the full set of info on my 2011.
