data logging
data logging
So I'm attempting to do data logging through my sct sf3 through my laptop and when i launch the program it says something about a database and basically the program just crashes.
Anyone have any experience with livelink 2 at all?
Pardon the question, as I might be doing this in the near future for remote tuning.
I have an SCT that came with my Maggie kit. How can I use it to "datalog"? I've never done that before.
For me, I installed LiveLink on my laptop, which is the program that does the datalogging. The unit itself should be able to do some, but it's easier on the laptop IMO, and it appears that you can track much more info with it.
Once that is installed you connect the X3 to your car and the laptop. You have to set up Livelink with all the parameters it will log, and there is a huge list to choose from. I'll look into how I set it up, not all the parameters will be available with every car. Once everything is set up, you run the log and drive around however you want to get the log. Typically it's 1-2 WOT runs, but I also did a few just tooling around town for the hell of it. When you want it to stop logging just hit stop.
It's not that hard, but it can be a PITA to start and stop the software while you're driving. SCT suggests having a passenger do all that, I'm lucky enough to have enough empty road by me where I can pull off and do it safely.
Oh, and I guess it would be prudent to add that after you stop the log, it saves it as an excel file. The columns are the various parameters (A/F, knock sensors, rpm, etc.) and the rows are time.
And here are the parameters I used (taken from another Mustang site). If you sending the log to a tuner it might be best to ask them what parameters they want.
Short term fuel trim bank 1&2
Long term fuel trim bank 1&2
Lambse bank 1&2
Measured AFR bank 1&2
MAF Frequency
MAF flow rate #/min
Knock sensor
Spark Advance V2
Throttle angle actual
Throttle angle desired
RPM
Lambse bank 1&2
MAF Frequency
MAF flow rate #/min
Knock sensor
Spark Advance V2
RPM
RPM
Short term fuel trim bank 1 and 2
Long term fuel trim bank 1 and 2
Measured AFR bank 1 and 2
Load
MAF frequency
Battery voltage
Etc actual angle
Spark Advance
Knock sensor
torque source
Coolant temp deg F
Intake air temp F
Air control temp 2 F (supercharged only)
variable valve timing intake cam angle
variable valve timing exhaust cam angle
9/8/15 10:45 AM
Detroit Steel
2007-2009 Shelby GT500
8/17/15 02:29 PM
