Confused myself...again. Track PKG VS Brembo PKG
Old Aug 14, 2012 | 09:49 AM
AMChief 5.0's Avatar
I've probably just confused myself from all the searching but can someone PLEASE clarify the 2 packages? First of all, does a 2013 Mustang GT Premium (Manual) come with 3.73 gears?
The Brembo brake package comes with:
  • Front: 14" Brembo® vented rotors with Brembo® 4-piston calipers
  • Rear: 11.8" vented rotors
  • Unique electronic stability Control® (ESC) tuning
  • 19" X 9.0 dark stainless painted aluminum wheels with 255/40R19 summer-only tires
  • Tire mobility kit replaces spare tire
  • Aggressive suspension tuning--is this the 55D Rear Springs?
Track Package:
Available only on manual GT Mustangs with a 3.73 axle, the package gives track enthusiasts an engine cooler, upgraded radiator, performance friction brake pads and the same Torsen® differential that's on Mustang Boss 302. The package includes everything in the current Brembo™ Brake Package, with 14-inch vented front discs, unique 19-inch alloy wheels and summer performance tires.
My question is--do you get different springs with the Brembo PKG and the Track PKG? Is the Track PKG the only option that comes with 3.73 gears?
Old Aug 14, 2012 | 10:16 AM
dusman59's Avatar
You can get 3.73 gears with the Brembo option but it is extra. The 55d springs are an after market mod that lowers the rear closer to the hieght of the front.
Old Aug 14, 2012 | 10:25 AM
Ahh, that's what I thought. So, if I were to order the Track Package, I would still want the 55d springs to "level" it off?
What about the springs? What's the difference between the stock GT ride height/springs VS the Brembo ride height/springs VS the Track Pack ride height/springs?
Old Aug 14, 2012 | 11:08 AM
Black Fire's Avatar
The BBP and Track Pack springs are the same. The TP just adds the better radiator oil cooler Torsen Diff. and 3.73 gears.
Old Aug 14, 2012 | 11:11 AM
newpony's Avatar
So Brembo Package doesn't include 3.73 anymore?
Old Aug 14, 2012 | 11:17 AM
Thank you for clarifying but I'm still waiting to hear if I would need to add the 55D rear springs myself to the Track PKG, to level it off... You can't get these from Ford, right?
Old Aug 14, 2012 | 01:01 PM
dusman59's Avatar
No there is a site that has them. Easy install. I think its brembo50.com. Too many speed bumps in AZ to go lower.
Old Aug 14, 2012 | 02:24 PM
Black Fire's Avatar
Never did... 3.73's are a seperate option.
The 55D springs are aftermarket.
http://brembo50.com/Default.aspx?pageId=1200846
Old Aug 14, 2012 | 05:34 PM
JScottGT's Avatar
The easy way to think about it:
There is the Brembo Pack, which gives you everything you list.
Then there is the track pack, which gives you everything in the Brembo pack PLUS:
Boss 302 rear axle assembly (Torsen, 3.73 gears, vented diff cover, painted axle assembly)
Boss 302 Radiator
Boss 302 Oil Cooler
Engine calibration for 5W50 Oil
Old Aug 14, 2012 | 07:22 PM
Xar's Avatar
Xar
Track pack is better - wish I had gone that route.
Old Aug 14, 2012 | 08:13 PM
TheDivaDanielle's Avatar
Wish I could get TP or 3.73's with a Convertible :-( stuck with 3.31's till I make a change.
Old Aug 15, 2012 | 06:16 AM
Is your stang a daily driver?
Old Aug 15, 2012 | 06:17 AM
Boss 302 Radiator
Boss 302 Oil Cooler
Thanks for clarifying. I'm on board now.
Old Aug 15, 2012 | 06:22 AM
Double-EDad's Avatar
Try to look at a few at the dealers but to me the Brembo pkg (BBP) cars look like they ride a little higher than the stock GT, which makes no sense to me; they look darn near ready to go off-road! Therefore there were some on this forum who said it's better to skip the BBP and just go aftermarket on the springs (this is what I did, Steeda Springs & Koni dampers, but 2011/12's had no BBP available with the 6AT). I know FRPP sells a Brembo conversion kit ($1150 from buyfordracing), but as pointed out the BBP is about more than just the brakes.
If buying a 2013 6MT now I would go with the BBP & Track pack & 3.73, & deal with/sort out suspension height issue later.
A 'vert note: before buying my '12 GT coupe 6AT, I had a 2011 GT convertible 6MT. To my eye the 'vert had an acceptable ride height & a nice ride (but floaty struts/shocks). One drive in a coupe GT loaner convinced me that the coupe was what I should have bought - the structural rigidity was much better & it felt like more of a drivers car. I'll spare u the long story on changing to the '12 coupe, but the ride was stiffer (no BBP mind you) & it just seemed to sit just high enough that it annoyed me. Didn't intend to modify it when I bought it but I figured if the ride is going to be firm anyway I may as well lower it so that's why I went with Steeda Ultralites. Since i was switching to Konis anyway - the incredibly floaty stock dampers convinced me I needed to upgrade to Koni dampers, which I'd been plotting to do on my '11 vert anyway. Not sure if BBP dampers would be better...
Old Aug 15, 2012 | 07:08 AM
Yeah, I was really just debating between then the BBP and TP. I think I'm going to just spring for the TP so I get it all.
Thanks for your insight!
Old Aug 15, 2012 | 08:15 AM
Stevedotmil's Avatar
I drive mine everyday. It does bug me that the car sits kind of high for my taste. I'm going with the Eibach Coilovers so I can dial the ride in perfect and never worry about it again.
09-gt/cs
Oct 15, 2015 10:03 AM
Bryanh24
Oct 14, 2015 08:43 AM
Kalel08
Sep 29, 2015 03:06 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
