Clutch Woes... At the dealer for 1-2 weeks
Old Jul 28, 2010 | 09:06 PM
Intervention's Avatar
So, let me start with saying my car has NOT been babied. While it hasnt seen the actual track, I must have powershifted it 100 or so times.
The car felt beautiful, it shifted like a dream. Never jammed up, or missed gears. It was fantastic. I loved the car so much, I have 4600 miles on my car and i've only owned it 27 days.
With all that being said, during Mustang Week (a 1000 mile road trip for me), the clutch all of a sudden drastically changed. It was no longer buttery smooth, but light at the top, and heavy at the bottom. The engagement point went from top/middle to 1/2" off the floor. The car was still 100% driveable, but just different. Saddly, the car would NOT shift right at high rpm (6500+) and it would lock out some of the gears. Most likely due to the clutch not disengaging correctly...
As soon as I got back to NH, I brought it to the dealer. At first they thought it was a leaky master cylinder, letting air into the system. However, after that was deemed not it, they are going to replace the entire clutch assemble. At least thats what I got out of the service manager. He said he would have more info for me tomorrow.
The bad news, they can not get the parts till August 5th, so my car will be out of commission for a while.
I am a huge Ford dan, and I still stand behind my mustang. But at the same time, I want to install longtubes and a catback, but dont want any trouble with the warranty. Hope this fixes the problem for good
Old Jul 28, 2010 | 09:12 PM
GRABOID's Avatar
Sorry but it won't fix it for good as you put it. The way you drive it's obvious you need a tougher clutch but that will also give out in time due to the way it is being drove. No majic bullet with "hot rods"
Old Jul 28, 2010 | 09:18 PM
Praetorian730's Avatar
You dont say
Old Jul 28, 2010 | 09:19 PM
Tony Alonso's Avatar
Gene K posted a thread about his clutch issues. I presume you've seen that, yes? Also, any thoughts on why you powershift so much? Are you racing the car?
Old Jul 28, 2010 | 09:23 PM
The clutch still grabs fine...
It is something either related to the pressure plate, or something in the pedal assembly
Old Jul 28, 2010 | 09:53 PM
97svtgoin05gt's Avatar
Beating up a car definitely reduces the time in which you'll need to seek repairs. The harder you run it, the more rapidly it'll exhibit issues. You've simply proven this. Continued driving this hard this often will cause the problem to re-occur.
Old Jul 28, 2010 | 10:04 PM
My 07 never had any pedal/clutch engagement issues...
She saw 400-500(100 of them on drag radials) 1/4 mile passes, all she ever needed was a replacement clutch
Old Jul 28, 2010 | 10:21 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
the new 5.0 mustangs are more high tech I guess. I do not think you would get 100 power shifts out of a ferrari
Old Jul 28, 2010 | 11:26 PM
Ducky's Avatar
http://www.lethalperformance.com/201...78_10279_10280
Old Jul 28, 2010 | 11:47 PM
Adam's Avatar
I've seen quite a few clutch issues.
Old Jul 29, 2010 | 06:06 AM
corvettedreamin's Avatar
Didn't I read somewhere that the clutch/trans is only rated for 375 HP?
Old Jul 29, 2010 | 06:23 AM
Double-EDad's Avatar
I think 375 ft.-lb. was the torque rating of the Made-in-China transmission.
Old Jul 29, 2010 | 07:12 AM
Eric... you're correct.. ft.lbs... not HP.... thanks for clearing that up.
And how much does the 5.0 generate?
Old Jul 29, 2010 | 07:50 AM
Stinger1982's Avatar
I am Shauny Clause
MOTM July 2010 Winner
This is a known issue
Its the bolts that hold the pressure plate to the flywheel, they are having trouble with them backing themselves out in certain circumstances and this is not a blanket (meaning everyone) issue, this is made worse by lots of high RPM usage.
Mine has already been replaced (2-3 weeks ago), I was the first one.
Ford Enginnering had to bring parts to my dealer to try, since no parts were available through normal channels.
I am running some new style bolts to see if they hold up better. My car is going back to Ford Corporate within the next two weeks for them to see how they held up.
Please PM me your vin and the name of the dealer the car is at.
Old Jul 29, 2010 | 08:13 AM
Rivets!
Hmmm.... wonder if this is going to affect my V6. They'll probably reprogram the PCM and lower the RPM limit.
I am Shauny Clause
Originally Posted by corvettedreamin
Rivets!
affecting only 5.0 manuals (as far as I am aware)
Old Jul 29, 2010 | 08:16 AM
Tranny and clutch are the same, no?
Perhaps my little V6 is too gutless to loosen the bolts... (sigh)
6k RPM at the transmission is 6K RPM regardless of motor.
Old Jul 29, 2010 | 08:18 AM
I am Shauny Clause
but we spin to 7............
Not one mentioned it to me during the course of our discussions I dunno man
Old Jul 29, 2010 | 08:21 AM
Well, given the delay on manual cars getting out, I wouldn't be surprised. But I'm not going to worry about it until it happens. Right now it seems fine. No point in dreaming up an issue that isn't there yet.
Heading to MI for another trip this weekend. We'll see how it goes. Should turn 5k+ miles by the time I'm back in VA on Sunday.
Old Jul 29, 2010 | 08:49 AM
Drew2000's Avatar
Hope this will be addressed in the "Job 2" cars.
