Clutch question
Old Feb 15, 2012 | 04:59 PM
sai's Avatar
sai
Clutch question
Hello
I recently purchased a 2012 gt with brembo pkg, everything is fine, i am enjoying the car, but my clutch is engaging almost at the point where I let my foot off the pedal, is that how it is supposed to work ? Also sometimes I start to move with second gear and I see a very little vibration when engaging, this also happens in 1st gear on a uphill start, anyone having similar issues ?
Old Feb 16, 2012 | 05:33 AM
Kobrag's Avatar
Le bump
Old Feb 16, 2012 | 05:45 AM
Sai I would think that is not normal there should be some play in the clutch pedal before engaging/disengaging. Take it in for a check up or at least go and ask a service advisor. As far as the vibration I don't get what your trying to say.
Romain that was one of the most helpful posts I have seen around here in a long time
Old Feb 16, 2012 | 06:18 AM
2012BLKV6's Avatar
Originally Posted by sai
Hello
hey sai, I have a 2012 v6 but it is the same clutch and trans. if by "engaging" you mean fully engaged then yes, that is normal. Try a no-gas start to really find your friction point. As for the vibration, that's just your motor lugging a little bit, give it a tiny bit more gas and see if this fixes your issue.
Old Feb 16, 2012 | 12:28 PM
sai's Avatar
sai
guys at what position of clutch pedal release does your car starts moving or it starts engaging the transmission ?
1.at half the way out
2.at all the way out
3.at almost near a point where pedal position is close to ground
Mine engages transmission at 2
Old Feb 16, 2012 | 12:30 PM
sai's Avatar
sai
What is no gas start, how to do it
Old Feb 16, 2012 | 12:53 PM
2012BLKV6's Avatar
its exactly what it sounds like. you can start from a stop (on flat ground) without touching the gas pedal. This will give you a much better idea of where the clutch starts to engage. Just put it in first (reverse is even easier) and slowly let out the clutch. When I do this I will start to move with the clutch about 2/3 of the way out.
EDIT: 2/3 not 1/3. iPhone keyboard =/
Old Feb 16, 2012 | 02:31 PM
sai's Avatar
sai
its exactly what it sounds like. you can start from a stop (on flat ground) without touching the gas pedal. This will give you a much better idea of where the clutch starts to engage. Just put it in first (reverse is even easier) and slowly let out the clutch. When I do this I will start to move with the clutch about 1/3 of the way out.
mine does it at 3/4 of the way out
Old Feb 16, 2012 | 02:50 PM
2012BLKV6's Avatar
My apologies for the typo. I meant 2/3 out. Seems like yours is normal
Old Feb 18, 2012 | 11:18 AM
jlmounce's Avatar
In my experience, Ford's clutch pedals have always had a rather early and quick engagement when compared to other vehicles I've owned and driven.
As long as it's not slipping, failing to disengage etc I would think this is probably just a characteristic of your car.
There are aftermarket products out there to help you adjust the pedal to a level better for you if it's that big of an issue.
Gill5oh
Oct 6, 2017 10:50 PM
MustangConvert11
Sep 30, 2015 08:01 PM
